Page 2 of 3 1 2 3
Re: 70 Cuda spare tire stud [Re: Snoopy] #28308
07/13/06 06:54 PM
07/13/06 06:54 PM
Indiana
W5Duster436 Offline OP
Indiana
Yeah, it just dawned on me that it's a 15" instead of a 14" right? I would've walked away had a I known this. Too late now I guess. Were the volare and aspens 15" spacesavers? Any idea what it would be off of?
Re: 70 Cuda spare tire stud [Re: W5Duster436] #28309
07/13/06 06:57 PM
07/13/06 06:57 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
You have a large problem. It is probably off of a 77-78 Chrysler product.
Goodyear G78-15 - Should be F78-14
DOT seems to be CUO 038
M87 Stamped between the stud holes - 1977 wheel
M87 and 9 to the left of the stem and an 8 to the right of the stem. - Sept 8, 1977 build date
369917 stamped in the rim above the stem. - Should have 7 digits 369917?
Re: 70 Cuda spare tire stud [Re: Snoopy] #28310
07/13/06 07:03 PM
07/13/06 07:03 PM
Indiana
Indiana
You have a large problem. The spare is probably for a GM or Ford product. Does the wheel bolt up to your car?
369917 stamped in the rim above the stem. Probably a GM part number.
Now I am ticked off! I can't EVER get a break but this was my error and should have known this stuff before I bought it. This guy is a BIG mopar guy and I took his word for it. I obviously didn't try to put it on the car and could easily check the bolt circle. I'll do that in a little bit. I am sure it'll be 4 3/4 probably.. LOL
Gonna make a phone call in the morning!
Okay you were right, the part number was 3699117 and there is a chrysler insignia to the right of the 8 on the rim so it is chrysler and does appear to be 4.5" bolt circle I believe.
Re: 70 Cuda spare tire stud [Re: W5Duster436] #28311
07/13/06 08:30 PM
07/13/06 08:30 PM
Zzyzx Road
beepbeep Offline
moparts member
beepbeep  Offline
moparts member
Zzyzx Road
Quite a bit of difference between a 14 and 15" SS.
Amazing how an unchallenged lie can become the absolute truth.
Re: 70 Cuda spare tire stud [Re: W5Duster436] #28312
07/13/06 08:49 PM
07/13/06 08:49 PM
Snoopy Offline
Snoopy  Offline
I wonder if it is from a 78 Super Coupe? If so, you should be able to get your money out of it.
Re: 70 Cuda spare tire stud [Re: beepbeep] #28313
07/13/06 08:58 PM
07/13/06 08:58 PM
Indiana
Indiana
The one on the right is exactly like mine. You did read my reply that it is a chysler rim? Not sure what a super coupe is? Is that the volare with ground effects etc? That definitely is the diff. in height that would make the nut go on a bit easier. I do have about 3/8" of thread but that's it. Let me know what you think. I may try to get my $ back tomorrow but I would guess it's highly unlikely.
Re: 70 Cuda spare tire stud [Re: Snoopy] #28314
07/13/06 09:01 PM
07/13/06 09:01 PM
Indiana
Indiana
If so, how much $ are you talking about? I paid 100 for the tire/rim and bottle/bracket.
Re: 70 Cuda spare tire stud [Re: W5Duster436] #28315
07/13/06 09:31 PM
07/13/06 09:31 PM
Snoopy Offline
Snoopy  Offline
I don't have a clue as to what it's worth. I would post that question on the General board. Those guys love to play WhatsItWorth.
Re: 70 Cuda spare tire stud [Re: Snoopy] #28316
07/13/06 10:58 PM
07/13/06 10:58 PM
Indiana
Indiana
I guess I need to find out if that's what it's for or not. I guess for now I'll keep it until I can replace it.
Re: 70 Cuda spare tire stud [Re: W5Duster436] #28317
07/14/06 05:06 AM
07/14/06 05:06 AM
Zzyzx Road
beepbeep Offline
moparts member
beepbeep  Offline
moparts member
Zzyzx Road
Okay, here are all the numbers:
Goodyear G78-15
I was told it was out of a mid 70's volare or aspen.
The 250 wheel with a F78-14 GOODYEAR tire was used on the Aspen/Volare. What you have was used on the B Body. Cordoba, Magnum, Charger etc...
Re: 70 Cuda spare tire stud [Re: beepbeep] #28318
07/14/06 07:26 AM
07/14/06 07:26 AM
Indiana
Indiana
Goodyear G78-15
What I have = Worthless
Gonna make the call this morning and see if I can get my $ back. Wish me luck.
Re: 70 Cuda spare tire stud [Re: W5Duster436] #28319
07/24/06 06:11 AM
07/24/06 06:11 AM
Snoopy Offline
Snoopy  Offline
Can someone post a picture of the 6" mounting stud? I plan to cut down the 9 1/2" stud that I already have and want to make sure it looks correct.
Re: 70 Cuda spare tire stud [Re: Snoopy] #28320
07/24/06 09:08 AM
07/24/06 09:08 AM
midwest
sg333e Offline
super street
sg333e  Offline
super street
midwest
I just removed mine from my cuda yesterday...I can post today. PM me if I forget.
Question: If I had the 6" stud, does that mean I had space saver? Can you extrapolate what size wheel/tire my car originally had from this?
Thanks,
EW
Hobbies and associated message boards: 1970 Cuda 440+6 FE5 H6X9 4 SP> Moparts.com 1987 Grand National (422rwhp/566tq)> TurboBuick.com 2008 BMW 335 TT 6MT> E90Post.com 2008 Gary Fisher HiFi Plus 29er > MTBR.com 2008 German Shorthair Pointer > Shorthairs.net
Re: 70 Cuda spare tire stud [Re: sg333e] #28321
07/24/06 10:38 AM
07/24/06 10:38 AM
Here is a pic of a stud for the space saver spare. It is about 6 1/2 inches long. The one for my convert is longer, about 7 inches. Hope this helps you.
Re: 70 Cuda spare tire stud #28322
07/24/06 11:35 AM
07/24/06 11:35 AM
Here is a pic of the correct space saver wheel. It is a 14x5.5 with no part number and a sixth hole across from the valve stem. These wheels were made by kelsey-hayes. The correct tires were bf goodrich(7.35,7.75x14 early 70) f 78 14.
Re: 70 Cuda spare tire stud #28323
07/24/06 11:55 AM
07/24/06 11:55 AM
midwest
sg333e Offline
super street
sg333e  Offline
super street
midwest
I'm trying to determine if my car came with 14's or 15's from the factory....your note above implies I would have had 14's? Was there a 15" space saver?
Re: 70 Cuda spare tire stud [Re: sg333e] #28324
07/24/06 12:17 PM
07/24/06 12:17 PM
e bodies never came with 15" space saver spares. The 15" space savers came in later and larger cars like the cordoba. They were g 78 15 goodyears.The f 78 14 goodyears came in aspen and volares.
Re: 70 Cuda spare tire stud #28325
07/24/06 04:23 PM
07/24/06 04:23 PM
Snoopy Offline
Snoopy  Offline
js27vob
Thanks for the picture. Now the only one missing is the stud for the standard spare.
Re: 70 Cuda spare tire stud [Re: Snoopy] #28326
07/24/06 05:32 PM
07/24/06 05:32 PM
Here is the one for the standard spare tire in an e body. This was in my 71 cuda but I am going to put a space saver in it.
Re: 70 Cuda spare tire stud #28327
07/24/06 07:31 PM
07/24/06 07:31 PM
Snoopy Offline
Snoopy  Offline
Thanks to js27vob, we now have a picture of each of the rods.
If anyone has any comments on the rods, speak up. I would like verification if possible.
2964999 - Space saver (23 & 29) 6.5"
3444581 - Space Saver (27 - Convertible - All Challengers) 9.5"
2964744 - Standard Tire Spare 10.5" Bend at Bottom???
Page 2 of 3 1 2 3
