Re: DRIVING IT TO THE TRACK
[Re: A/MP]
#2827918
10/02/20 02:33 PM
10/02/20 02:33 PM
Posts: 17,864 S.E. Michigan
ZIPPY
S.E. Michigan
Best 11.02 @ 123, But it usually runs 11-teens or low 20s through the mufflers on DOT tires. 451 low deck built by me/machined and balanced professionally, 10.75:1, rpm heads, PRH solid roller .631/.262/266, victor/1000 or 950 carbs 2" super comps, homemade exhaust, 727 with 9.5" converter, 4.10 Dana.
The 451 engine was a giant step up from the former 484 cam, stock piston smog 440 that ran pushed the car to 12s for what seemed like forever.
I haven't raced it since last May 5th and didn't really prepare the car other than taking everything out of the trunk. I forgot to drop tire pressure and had 20lbs cold in the quick time pros at the time, which in retrospect was stupid of me, but whatever. I just wanted to drive the darn thing and concentrate on doing that. It went 7.15, 7.16, 7.17, 7.17 and then loaded up and drove home.
I don't own a trailer but have been looking at them for awhile, and might go that way at some point.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2828010
10/02/20 05:57 PM
10/02/20 05:57 PM
Posts: 12,394 Taxes & Virus's R-US, NY
Dragula
I have driven my 9 sec Cuda to the track......I don't do it often, as I am not into changing tires at the track, but I have done it. When I have, its on a DOT cheater tire and runs 9.80's. Been wanting to do drag week with it for years. I have my doubts the big Hemi would hold up. I think a G3 Hemi would be a much better option and hold up to the abuse a lot better....
[Re: Dragula]
#2828050
10/02/20 07:53 PM
10/02/20 07:53 PM
Posts: 2,464 Sydney,Australia
tex013
Sydney,Australia
This is my Plymouth . It is a 505 now . This was after 14hr highway run . 6.52 in 1/8@105 . Then a 12hr run home . I have done similar runs on the 440 .
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#2828117
10/02/20 10:31 PM
10/02/20 10:31 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I have a 416ci Rampage that is my street rod.. I mainly run the streets with it but I did take it to the track once so far.. it ran 10.17 at 131mph with a 1.32 60'.. it has more in it.. its Holley injected and the day I ran it it was 2820 lbs(full tank with me) it has a 518 trans with 4.10 gears but at the track I dont use OD.. its a fun street rod
[Re: MR_P_BODY]
#2828618
10/04/20 02:55 PM
10/04/20 02:55 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
My D50 is a small block, 394ci, 10.9 comp. ,Indy 360-2 Brett Miller heads. PTC 8 in. Converter, 3.50 rear gears, MT drag Radials, mufflers. Drive to track let it cool off and run 6.20"s @110 in the 1/8. Needs a looser converter, only foot brakes to 2900 rpm. Crossing the finish line in 2nd gear.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
