Stage V 440 to Hemi conversion heads
#282641
04/09/09 04:41 PM
04/09/09 04:41 PM
Posts: 322 Itasca, Texas
Mad_Scientist
Itasca, Texas
How many people have these heads and what did you have to do to your block to make them fit? Is it feasible to make the modifications to an assembled short block, or are we talking major machine work? How was the pricing? Would I just be better off to buy a crate Hemi? Current setup is a mild 440 that is set up for street use, but I really want a Hemi instead. Stage V
69 Super Bee 440 5-speed 70 Dart Swinger 340 4-speed 69 Camaro SS 396 4-speed 66 Cutlass Convertilbe 70 Judge Ram Air III 4-speed 68 F-100 SWB
Re: Stage V 440 to Hemi conversion heads
[Re: Mad_Scientist]
#282642
04/09/09 05:00 PM
04/09/09 05:00 PM
Posts: 74,979 U.S.S.A.
JohnRR
U.S.S.A.
Stage V
I don't think you can even get those heads new anymore , when they first came out they were about 5k with the rocker system and that was a decade or so ago and when hemi blocks were hard to find .
build a hemi .
[Re: Mopar_Rich]
#282646
04/09/09 08:54 PM
04/09/09 08:54 PM
Posts: 12,385 Taxes & Virus's R-US, NY
Dragula
The conversion heads ARE available. I talk to Eric all the time and I just bought a set for a customer a few months back. They require special rocker arms and the block has to be ground for pushrod clearance. It's not something you can do after the fact.
I have done a few of these and I spec a custom cam too because the exhaust rocker ratio is only 1.4:1.
I would take a set for the right price...My engine guy built an engine with a set a while back, and they make the Hp as they claim they do, but as stated, the block needs some pretty serious work to it.
[Re: Mopar_Rich]
#282648
04/10/09 08:45 AM
04/10/09 08:45 AM
JohnRR
U.S.S.A.
Over the last year ... maybe 2 ... or so I have seen threads were people asked about these heads and the replies were that there weren't any available at the time and there was no plan in the near future to run them because they were busy making heads for real hemi blocks .
SORRY ...
[Re: roadrunninMark]
#282653
04/11/09 07:44 AM
04/11/09 07:44 AM
Dragula
For those unaware, these are not a super simple bolt on, they require some block work that has to be done right. The rotating assembly will be custom to, no kits currently available will fit them. The oiling system will almost have to be an external one, and you will need a bigger pan. The heads will hold a lot of oil up top, and it can drain a stock pan in a hurry.
Also, because your using a 440 block, its weaker because its not cross bolted. You might not think that's an issue until you bolt on heads that flow in the neighbor hood of 400cfm and the thing revs like a prostock engine. So now you have this big stroker kit in the block that revs like wicked in a less than appropriate block.....Thoughts to be considered when going down that path!
[Re: Mopar_Rich]
#282655
04/11/09 09:14 AM
04/11/09 09:14 AM
Dragula
Eric sent me an email LAST NIGHT. He will have the castings in stock by next week. The rocker system is different, as I said, but he has those in stock now. I see no reason for a delay - at least not now. Here's his email to me:
Hello Rich: The conversion head castings are supposed to arrive at our shop next week. We will run them through immediately. Rocker assemblies I already have. Thanks Eric
Rich,
Did you get any prices?
[Re: Dragula]
#282656
04/11/09 12:15 PM
04/11/09 12:15 PM
Posts: 2,402 Wichita,KS
Blakcharger440
Wichita,KS
Hmmmm...sounds like there are a few other things that i didnt think about when considering those heads. Waaaay too much to change just to run those heads. A person would be better off just buying a real Hemi block and regular Hemi heads since all those changes would need to be done.
[Re: Blakcharger440]
#282657
04/12/09 11:12 AM
04/12/09 11:12 AM
JohnRR
U.S.S.A.
WINNER ding ding ding ... WINNER ... ding ding ding ...
#282658
04/12/09 01:31 PM
04/12/09 01:31 PM
Posts: 1,938 Sonora CA
Mopar_Rich
Sonora CA
I would also like to know what the price of the kit is or who to email for more info.
Mark
I just got back from a race and Eric's email was there. $2950 a set. But remember, you have to use the special Stage-V rocker system too. So that has to be added in. (sorry no price on that yet)
As too the difficulty, there are a few issues but nothing outrageous. The problem was that there's no head gasket that will directly work. I took a stock Fel-Pro 1009 and cut and nicked it until everything cleared. You do have to grind the block for pushrod clearance, but it's not a big deal and I'm used to this with a Hemi. As to the mains, most of my customers that did this conversion were building street engines and were not going to race. Show - not go.
Randy brings up a good point with the oil drain back. That is an issue if the engine is kept higher in the RPM range. I think it was my second conversion customer that cruised his car with a 4.11 rear gear and he saw a drop in oil pressure at highway speeds because the pan was being pumped dry. He took care of it by changing the pan and running a thinner oil. If I ever do another one I'd drill out the drain back holes slightly, and paint the valley area with a gloss paint.
The exhaust on these heads are typical Hemi size, shape and bolt pattern. So normal Hemi header flanges are used if you fab a set of custom headers. Clearance around the wedge motor mounts and starter is always an issue, but both of the installations I saw used motor plates and they cut off the wedge flanges. It worked.
[Re: JohnRR]
#282659
04/12/09 01:35 PM
04/12/09 01:35 PM
Mopar_Rich
Sonora CA
But wait , in the other POST you said they were already available ???
By "available" Eric means that he's still making them! They are never just sitting on the shelf.
