Re: Hood scoop performance ..
[Re: carnut68]
#2826685
09/29/20 10:41 PM
09/29/20 10:41 PM
Posts: 5,108 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
Yes there is an aerodynamic factor is every car and 150 MPH things begin to happen with a lot of cars. The 1965 SSBA car is stable at 154. Another friend SS 1968 Barracuda with a big aluminum hemi ran 830 and did not fully complete the pass under total power because the air was getting under the car and making the nose super light and scary at 170 mph. The Barracuda races Hemi Shoot outs and Cam AM so making it slower was a good thing. The sealing to the hood has to be tested with every car and motor combination. Might work might not the answer with be in the Time Ticket. There will be a lot of pressure on the hood so it better be bolted down right and a strong hood.
1971 HEMI E BODY REGISTRY
[Re: hemicar1971]
#2827631
10/01/20 10:09 PM
10/01/20 10:09 PM
Posts: 2,509 PA
moparacer
PA
I am going to fabricate a scoop for my car and will post the results when I run it next weekend. I have been running hoodless with a uni filter so I suspect it will pick me up several hundredths. Mocked one up in carboard today. To check left lane tree vision. If this works good I will fit a hood around it over the winter. Trying to get a 5.40 1/8 mile pass before year is out.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: moparacer]
#2827647
10/01/20 11:11 PM
10/01/20 11:11 PM
Posts: 20,597 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
In an old issue of Mopar Collectors guide they did a feature on a white 68 hemi cuda race car and the owner cut about a 1" or so opening across the back of the hemi scoop to let some of the excess air escape. With it enclosed on all 3 sides the volume of air at the top end was pulling the hood scoop and hood apart at the front corners. For a real fast car this may be something to consider doing??? Here is the car that I'm talking about. https://www.dragracecentral.com/DRCStory.asp?ID=22155
[Re: moparacer]
#2827715
10/02/20 07:30 AM
10/02/20 07:30 AM
Posts: 2,924 A shed in England
Tig
A shed in England
Mocked one up in carboard today. To check left lane tree vision. If this works good I will fit a hood around it over the winter. Trying to get a 5.40 1/8 mile pass before year is out. Edit, Thought about a clear perspex scoop ?
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: one bad fish]
#2827781
10/02/20 10:20 AM
10/02/20 10:20 AM
Posts: 2,509 PA
moparacer
PA
I am considering running a cowl hood like that setup to smooth airflow up into the scoop if my setup works. Although not as tall as that one.
[Re: moparacer]
#2827792
10/02/20 10:46 AM
10/02/20 10:46 AM
Tig
A shed in England
There are a few posts about the perspex scoops on The Bullet, not many back to back tests but most claim 1 - 1.5 tenths and around 3 mph improvement. https://www.yellowbullet.com/threads/lexan-carb-scoop.567887/HTH's
[Re: moparacer]
#2827799
10/02/20 11:04 AM
10/02/20 11:04 AM
Posts: 1,534 bronx n.y
one bad fish
bronx n.y
I am considering running a cowl hood like that setup to smooth airflow up into the scoop if my setup works. Although not as tall as that one. kool
[Re: Since1822]
#2827825
10/02/20 11:44 AM
10/02/20 11:44 AM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
A few weeks back I posted results regarding my hood. I have a 68 roadrunner with six pack hood on it. Victor intake and 2" super sucker put the dominator vent tubes about 3/8" away from the underside of the hood. During test and tune we took the hood off and replaced it with a 4" K&N air filter with x stream top, 14" diameter. We gained three tenths from the previous run. My hood is not sealed to carb, but do pay attention to how close the carb is to the underside of the hood. I went 11.52 with the hood and 11.20 with air cleaner and without hood. +3mph Have you tried the hood without the carb so close to it? My vent tubes are probably 3" from the roof of my scoop.
[Re: A/MP]
#2827828
10/02/20 11:48 AM
10/02/20 11:48 AM
Posts: 16,483 On the run…
BloFish
On the run…
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: bigdad]
#2827867
10/02/20 01:01 PM
10/02/20 01:01 PM
Posts: 4,206 New York
polyspheric
New York
"Excess air!" Where can I buy some of that?
Boffin Emeritus
[Re: justinp61]
#2827885
10/02/20 01:31 PM
10/02/20 01:31 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
Yes sir and cutting 5 tear drop holes in the rear made the afr's more stable and solved some siphoning issues w/the bowl vents as well......
[Re: polyspheric]
#2827900
10/02/20 02:04 PM
10/02/20 02:04 PM
Posts: 22,696 Bitopia
jcc
Bitopia
"Excess air!" Where can I buy some of that? It's right here in this thread, and free, but don't take to much it will blow you away.
[Re: bigdad]
#2827956
10/02/20 04:01 PM
10/02/20 04:01 PM
polyspheric
New York
I understand and agree with owners/builders reporting their own experiences. What I find fault with is the idea that if these events actually occurred (and we take your word for it) that witnessing the event gives you some special insight as to exactly what caused the effects: causation vs. coincidence is perhaps the largest single fallacy in analysis. Unfortunately, although I am not by nature a lazy person, there are simply too many non sequiturs, false conclusions, rationalizations, and "it stands to reason" assumptions for a comprehensive response. Those who would enjoy reading my opinion can PM me. Thanks.
Boffin Emeritus
