Re: MAGNUM HEAD FLOW RESULTS [Re: RyanJ] #2820
08/23/03 12:48 AM
08/23/03 12:48 AM
Amarillo, Texas
65Dart270 Offline
65Dart270  Offline
Amarillo, Texas
I understand there is going to be some variance between benches, Ryan, I was just trying to make a ballpark comparison.
So, that being said, and with those numbers above, what would you say the best cast iron ported head below a W-2 would be for the money?
"Although prepared for martyrdom, I preferred that it be postponed."
Sir Winston Churchill
Re: MAGNUM HEAD FLOW RESULTS [Re: 65Dart270] #2821
08/23/03 01:15 AM
08/23/03 01:15 AM
State College, PA
RyanJ Offline OP
moparts member
RyanJ  Offline OP
moparts member
State College, PA
Cast Iron? Who wants cast iron? LOL Umm..............2.02" in a magnum, got to be best iron for the $ IMO. They have alot of advantages over old J heads etc. Better chamber, better wet flow, better exhaust (maybe LOL), lighter valves, round lock grooves, 10 valve cover bolts, just alot better catsings, hardened seats etc etc etc. Magnums are "the deal" IMO. Stuff an AMC pushrod oil lifter in it, hollow pushrods and run 'em.
Re: MAGNUM HEAD FLOW RESULTS [Re: RyanJ] #2822
08/23/03 12:17 PM
08/23/03 12:17 PM
73E360 Offline
73E360  Offline
Not quite like having them on your bench, but here is a link to some pictures of the R/T and Magnum heads side by side.
http://www.geocities.com/alwest_83/magnum.html
Jeff
Re: MAGNUM HEAD FLOW RESULTS [Re: 73E360] #2823
08/23/03 12:48 PM
08/23/03 12:48 PM
State College, PA
RyanJ Offline OP
moparts member
RyanJ  Offline OP
moparts member
State College, PA
I need to stick my fingers in an R/T intake port..... I could tell you within 10 seconds how much better they would be. Pics are OK, but you can't tell everything from a photo.
Re: MAGNUM HEAD FLOW RESULTS [Re: RyanJ] #2824
08/24/03 04:58 PM
08/24/03 04:58 PM
British Columbia
toddd Offline
toddd  Offline
British Columbia
Any idea what the increase in flow would be using then MP porting templates?. I was also planning on going to the 2.02 intake.
How long did it take you to port the set you took the pics of?. Thanks .
Re: MAGNUM HEAD FLOW RESULTS [Re: toddd] #2825
08/24/03 05:04 PM
08/24/03 05:04 PM
State College, PA
RyanJ Offline OP
moparts member
RyanJ  Offline OP
moparts member
State College, PA
I'll probably have 20 hours total in these heads. 1.5 Hrs per intake port and 1 hour per exhaust.
No idea about the porting templates....
Re: MAGNUM HEAD FLOW RESULTS [Re: RyanJ] #2826
08/24/03 05:42 PM
08/24/03 05:42 PM
aZLiViN
J_BODY Online rolleyes
J_BODY  Online Rolleyes
aZLiViN
More tidbits for the smallblock stew brewing here. My dad runs the Mopar Performance iron heads that were discontinued awile back. He bought them bare and had them ported and fitted with Manley chevy valves with the smaller stem.
Intake 28" h2o 1.96 valve:
.100= 74.7
.200= 140.9
.300= 193.5
.400= 224.2
.500= 242.0
.600= 242.2
Exhaust 1.60 valve
.100=53.1
.200= 107.1
.300= 147.2
.400= 167.0
.500= 177.6
.600= 182.3
I'll try to dig up a part number but I believe they were the old "swirl port" head. He has just bought some w-2's for next years project. "As is", they didn't flow any better than the heads he's running now (same bench).
Re: MAGNUM HEAD FLOW RESULTS [Re: J_BODY] #2827
08/24/03 05:51 PM
08/24/03 05:51 PM
State College, PA
RyanJ Offline OP
moparts member
RyanJ  Offline OP
moparts member
State College, PA
I could have told you that LOL. They will RESPOND to porting though LOL. 300/210 cfm easy
Re: MAGNUM HEAD FLOW RESULTS [Re: RyanJ] #2828
08/24/03 11:50 PM
08/24/03 11:50 PM
Tampa, FL
tpabayflyer Offline
tpabayflyer  Offline
Tampa, FL
I ported a set of magnum heads about 3 years ago and spent about 50 hours doing it!!! cast iron dust everywhere!!! next time( if there is a next time) I will use a mask as I started catching a buzzz after breathing all that dust .... My hand was also numb for about 2 weeks after all the grinding with my dremel grinder... but I was pretty happy with the end result as all I did was clean up the bowls but they really needed lots of grinding as the valve guide bosses have so much extra meat around them.... I used these heads on a 360 and they ran very well.. I currently have them on a 70 318 with headers and this thing has so much more power it's unbelievable.... The tall, skinny ports give good velocity and these heads make a nice choice for a street/strip setup.. based on how well they work on my brothers 318, I would say these heads are a great choice for a 318 .... Eventually, These heads will make it to my 109K mile 5.2 Grand Cherokee and I just might throw a 4" crank at it as well TBF
71 Challenger 528 Hemi project
09 Gr Cherokee 5.7 hemi in da house!!
Re: MAGNUM HEAD FLOW RESULTS [Re: tpabayflyer] #2829
08/26/03 02:31 PM
08/26/03 02:31 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
hey ryan, just curious if you'd cc'd a port yet, and how the port volume compares with some other "street" heads you've done
2017 Grand Cherokee Overland
Re: MAGNUM HEAD FLOW RESULTS [Re: toddd] #2830
08/26/03 02:37 PM
08/26/03 02:37 PM
In the twisties
RokketRide Offline
super gas
RokketRide  Offline
super gas
In the twisties
Porting templates recommend 1.97 intake.
I ported my heads at home using the templates (with the 1.97 intake). With 6 miles on the odometer took a trip to the dyno, made 342hp at the wheels (with PS, Auto and an 8 3/4)
Re: MAGNUM HEAD FLOW RESULTS [Re: patrick] #2831
08/26/03 03:09 PM
08/26/03 03:09 PM
State College, PA
RyanJ Offline OP
moparts member
RyanJ  Offline OP
moparts member
State College, PA
Ported 1.92" Magnum = 183 CC's
Re: MAGNUM HEAD FLOW RESULTS [Re: RyanJ] #2832
08/26/03 11:57 PM
08/26/03 11:57 PM
73E360 Offline
73E360  Offline
Really 183? Rumor had it that later-model 5.9's had larger 163cc ports (versus the 5.2L 153cc ports). The casting number you refer to is supposed to be the larger 5.9L head.
Did you measure before porting? Did you really take 20cc out of the bowl or did you go into the throat and runner to get that volume?
Jeff
MAGNUM R/T HEAD PICS [Re: 73E360] #2833
08/27/03 02:15 AM
08/27/03 02:15 AM
Amarillo, Texas
BBR Offline
BBR  Offline
Amarillo, Texas
Just got my heads. Wow. I like them so far.
Not the greatest pics in the work, but hey, they are better than none!
Drag Week 2011 - 77th place - DD
Drag Week 2012 - 2nd place SRBB N/A
Drag Week 2014 - Kapooya
RMRW 2018
RMRW 2020
Re: MAGNUM R/T HEAD PICS [Re: BBR] #2834
08/27/03 02:52 AM
08/27/03 02:52 AM
Peoples Republic of Boulder, C...
worthywads Offline
worthywads  Offline
Look just like mine, real rough in the exhaust. With stock retainers/keepers I was way under the 1.64 spring height MP advertises, more like 1.595, but consistent. With hughes retainers (advertised plus 0.125, they were actually almost perfect at plus 0.045?) got me 1.64 for hughes springs spec'ed for 1.66.
I spent maybe 5 hours cleaning up and polishing the exhaust, definitely a lot a meat in the casting to machined area of the exhaust port, and around the valve guide.
The intake I only spent 3 hours (got the feel for the bit)as it was much "cleaner?" around the casting/machined area, but I did shave a good 0.080 off the pushrod pinch, and gasket match. Didn't spent much time at all around the valve guide, much more intimidating to me, hard to control the bit so I left it alone.
I also eliminated thread bulges where ever they could be found. This was my first porting (if you can call it porting).
Re: MAGNUM HEAD FLOW RESULTS [Re: RyanJ] #2835
08/27/03 08:06 AM
08/27/03 08:06 AM
Ryan very nice work keep up the good work and all the info you supply us on small block cyld heads your very helpful to a lot of people would like to see other shop post there numbers dont think your going to find anyone out there doing any better work then you thats for sure keep up the great work
Re: MAGNUM HEAD FLOW RESULTS #2836
08/27/03 11:37 AM
08/27/03 11:37 AM
State College, PA
RyanJ Offline OP
moparts member
RyanJ  Offline OP
moparts member
State College, PA
From what I can see, I'm in LOVE with those Magnum R/T's.......
Re: MAGNUM HEAD FLOW RESULTS [Re: RyanJ] #2837
08/27/03 11:47 AM
08/27/03 11:47 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
wow 183cc, that's bigger than I expected...is that about the same as a ported 360 or eddie? the 302's, werent those down near 145 or was is 163cc finished?
one more dumb question: chamber size-- how does it compare to the eddies and 302's?
Re: MAGNUM HEAD FLOW RESULTS [Re: RyanJ] #2838
08/27/03 05:14 PM
08/27/03 05:14 PM
Amarillo, Texas
BBR Offline
BBR  Offline
Amarillo, Texas
If *you* love them. I wanna marry them.
Any more standard Magnum numbers?
RMRW 2018
RMRW 2020
Re: MAGNUM HEAD FLOW RESULTS [Re: BBR] #2839
08/27/03 06:45 PM
08/27/03 06:45 PM
State College, PA
RyanJ Offline OP
moparts member
RyanJ  Offline OP
moparts member
State College, PA
LOL.....
Actually while the electricity was off here ALL FREAKING DAY....... I did manage to CC a Magnum Chamber. 63 CC's as cast.
As far as flow #'s.... no new ones to report, I'm trying to knock out these Large Port Commando's I have here before finishing the magnums. So it's going to be another week or so before I have new #'s to report, specifically exhaust #'s.
