Page 3 of 3 1 2 3
Re: You guys running antifreeze right now? [Re: rebel] #281843
04/10/09 07:45 PM
04/10/09 07:45 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
all I know is my late model Vette ran 215 all the time all I did was add a bottle of WW and it drop the temps to 200 all the time so for me it work at lowering the operating temp of that car.
Thats all I have in the race car water and WW and I run the fan very little to keep the temp up to 180
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: You guys running antifreeze right now? [Re: dusturbd340W5] #281844
04/10/09 07:51 PM
04/10/09 07:51 PM
Johnstown
69dart Offline
69dart  Offline
Johnstown
I 2nd the pitcocks in the block. I open them up at the end of the year and let it sit all winter.
33 Plymouth Roadster - 383 - 5.90 1/8th 9.58 1/4
68 Dart - 340
66 Belvedere - 400
Windy Hollow Garage - https://www.youtube.com/@windyhollowgarage
Re: You guys running antifreeze right now? [Re: 69dart] #281845
04/10/09 08:23 PM
04/10/09 08:23 PM
Westbury, NY
cowbay Offline
cowbay  Offline
Westbury, NY
I have petcocks on my block. I drain the antifreeze out in the spring and run water with WW for spring through fall
"Alcohol is for drinking, gas is for cleaning parts, and nitro is for racing!" original author unknown, used by Gene Adams and Don Garlits among others
Re: You guys running antifreeze right now? [Re: rebel] #281846
04/10/09 11:59 PM
04/10/09 11:59 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Water Wetter actually by itself doesn't reduce temps.It's really a surfactant agent.
Nautilus Racing-
Re: You guys running antifreeze right now? [Re: rebel] #281847
04/11/09 12:10 AM
04/11/09 12:10 AM
Dunedin, Fl
DRDart Offline
mopar addict
DRDart  Offline
mopar addict
Dunedin, Fl
[quoteBut what about it's ability to transfer heat fast/beter than antifreeze or water?
thats where the water wetter fell short, the antifreeze excelled on thermal transference & anti freezing capabilities over WW. in our country you can name products that you compare yours too. WW claimed their product was the best & named Prestone amoungst others. Prestone agent paid for an independant test & it was proved WW was rubbish. Very hard to find WW now.
Water wetter is not an antifreeze. it enhances the coolants ability to transfer heat better.
[image]http://i682.photobucket.com/albums/vv183/DrDart500/DSC00307.jpg 1966 Charger 1970 Dart 16-1,solid roller,500 ci Tunnel Ram 8" Ati conv,BTE glide, Fab 9 rear strange center sect. Twin Rons terminators on Alky.
Re: You guys running antifreeze right now? [Re: DRDart] #281848
04/11/09 07:55 AM
04/11/09 07:55 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
I forgot to mention...when we did race and all the antifreeze was drained I would use Royal Purple's Purple Ice...its not an antifreeze,its a synthetic that provides lubrication for the pump and it does help in lowering boiling tempuratures...
I like it better than wetter water...
Re: You guys running antifreeze right now? [Re: smokinwoody] #281849
04/11/09 10:31 AM
04/11/09 10:31 AM
Ohio
3404 Offline
3404  Offline
Ohio
I never seem to have my motor in my car whenit's that cold. Time I get it back together it will be just water wetter time.
Re: You guys running antifreeze right now? [Re: 3404] #281850
04/11/09 11:09 AM
04/11/09 11:09 AM
PA
moparacer Offline
moparacer  Offline
PA
All water pumps be it stock or electric have sealed bearings.
If you can dump anything in the coolant that actually lubes the bearings on any water pump, you need a new water pump!.....
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: You guys running antifreeze right now? [Re: moparacer] #281851
04/11/09 11:55 AM
04/11/09 11:55 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Actually the lubricant is for the seal to keep it from "going dry" in plain hot water.
Gus
64 Plymouth Savoy
Dana 60
Re: You guys running antifreeze right now? [Re: moparacer] #281852
04/11/09 11:55 AM
04/11/09 11:55 AM
Dunedin, Fl
DRDart Offline
mopar addict
DRDart  Offline
mopar addict
Dunedin, Fl
That is just funny right there
Page 3 of 3 1 2 3
