You guys running antifreeze right now?
#281803
04/08/09 08:59 PM
04/08/09 08:59 PM
Posts: 17,924 Akron, Ohio
ProSport
Akron, Ohio
My car is sitting here ready to fire up but I'm afraid to put water in it as we're suppose to get some 28-32 degree nights this week. I have some antifreeze but then I'll have to mess with trying to flush it all out in a couple weeks. What's the easiest way to do that? I usually just drain the radiator but that doesn't get it all out.
Re: You guys running antifreeze right now?
[Re: ProSport]
#281806
04/08/09 09:02 PM
04/08/09 09:02 PM
Triple Threat
Renton Washington
Easiest way would be to drain the Radiator and if the block still has a working drain in each side, let those babies flow as well.
Otherwise set up a heater in the garage, its really gonna have to freeze to hurt anything.
[Re: nss guy]
#281810
04/08/09 09:09 PM
04/08/09 09:09 PM
ProSport
Akron, Ohio
Your not suppose to ask a racer about that, tmi
Yea Jim I often wonder how many people actually drain the antifreeze out.
[Re: Dodgetony]
#281811
04/08/09 09:11 PM
04/08/09 09:11 PM
ProSport
Akron, Ohio
It's spring time in Northern Ohio....why would you need anti freeze?
I know Tony, it's April 8th and it's suppose to be freezing every night.
I'll go fill the system right now with some antifreeze added.
[Re: ProSport]
#281813
04/08/09 09:39 PM
04/08/09 09:39 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
I thought I spied a pretty nice heater in that garage of yours.
Oh yeah, I have antifreeze in mine
[Re: WILD BILL]
#281815
04/08/09 09:52 PM
04/08/09 09:52 PM
Posts: 4,852 KENTUCKY
69CHARGERMD
KENTUCKY
went racing a few weeks ago....and didnt want to run any antifreeze that i had in from over the winter... I drained the anti-freeze out by pulling the bottom hose, filling it back with water,,turned on my electric water pump x few minutes to circulate it,,,and dilute things out... It took about 4 cycles of pulling the bottom hose,,,adding water to the rad,,running the pump before i got all the antifreeze out of it..took about 15 minutes total The weather got cold again,,,,so,,,i put antifreeze BACK in the car,,,,and will have to do the whole process again,,, i cant to my plugs on the block very easy,,,but that would be even easier,,,
[Re: Ben Holt]
#281820
04/08/09 11:28 PM
04/08/09 11:28 PM
Posts: 3,354 ohio
HEMIDARTS
ohio
The company next door to us sells and installs portable carpet cleaning machines, the ones in the vans. They use windshield washer fluid to winterize the machines if they will sit out over the winter. Cheap, easy to clean, and 10 times easier to clean up if spilled at the track.....
Just a little helpful info.
Ben your post got me thinking. Has anyone tried this in a race car? Has anyone ran windshield washer fluid in a race car?
[Re: HEMIDARTS]
#281821
04/08/09 11:34 PM
04/08/09 11:34 PM
WILD BILL
BROOK PARK, OH
Well,
it is BLUE
[Re: WILD BILL]
#281822
04/08/09 11:36 PM
04/08/09 11:36 PM
Posts: 3,354 ohio
HEMIDARTS
ohio
Well,
it is BLUE
Technically some of it is red,or yellow, and i think they even make it in green.
[Re: HEMIDARTS]
#281823
04/08/09 11:49 PM
04/08/09 11:49 PM
Posts: 1,165 Central Ohio, USA
Bigbeep
Central Ohio, USA
Hey Bob, last fall before the Halloween Classic, my brother and I both put block heaters in our cars. Now, I still had antifreeze in the car for that race, but it would keep the coolant about 140-150 degrees. You know how long it is between rounds up there, so make a pass and plug it in to keep the heat in the motor. Just a note, I got it fom a federated auto parts store for like 25 bucks. Probably saved that in fuel in just that week. Beep
[Re: HEMIDARTS]
#281824
04/08/09 11:53 PM
04/08/09 11:53 PM
WILD BILL
BROOK PARK, OH
Well,
it is BLUE
All washer fluid is Blue.
Everything else is Kool Aid W/ an identity complex
[Re: WILD BILL]
#281825
04/08/09 11:56 PM
04/08/09 11:56 PM
Triple Threat
Renton Washington
My car sits outside year round, in Seattle. So yeah, its got antifreeze in it.
[Re: WILD BILL]
#281826
04/09/09 12:02 AM
04/09/09 12:02 AM
Posts: 3,354 ohio
HEMIDARTS
ohio
Well,
it is BLUE
Well what about this? but technically you are right, washer fluid is blue.
[Re: Triple Threat]
#281827
04/09/09 12:02 AM
04/09/09 12:02 AM
WILD BILL
BROOK PARK, OH
Are you sure
Kool Aid can be pretty sneaky.
[Re: HEMIDARTS]
#281829
04/09/09 12:35 AM
04/09/09 12:35 AM
Posts: 2,611 Elbridge, NY
Dart1031
Elbridge, NY
I know a guy who's used washer fluid in his race cars for over 20 years for this very reason.
[Re: 69CHARGERMD]
#281833
04/09/09 02:03 PM
04/09/09 02:03 PM
WILD BILL
BROOK PARK, OH
I think it varies on the track
Kool Aid is always good though
[Re: 340SIX]
#281834
04/09/09 07:10 PM
04/09/09 07:10 PM
Posts: 3,874 Smyrna, South Carolina
STEFF
Why not run it year round? Ok I am not the smartest person here But I can learn or at least I think I can
You're not supposed to run anti-freeze at the drag strip. If you have a coolant leak & it gets all over the track, it's difficult to clean up & increases the down time, due to that. It's kind of a racer courtesy.....no antifreeze at the track.
[Re: JoWeTu_6]
#281836
04/09/09 08:31 PM
04/09/09 08:31 PM
dartman366
Mt. Vernon, Ohio
No antifreeze here, just water and water wetter,,,,,and the car sit's in a heated garage all winter.
[Re: rebel]
#281843
04/10/09 07:45 PM
04/10/09 07:45 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
all I know is my late model Vette ran 215 all the time all I did was add a bottle of WW and it drop the temps to 200 all the time so for me it work at lowering the operating temp of that car. Thats all I have in the race car water and WW and I run the fan very little to keep the temp up to 180
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: 69dart]
#281845
04/10/09 08:23 PM
04/10/09 08:23 PM
Posts: 264 Westbury, NY
cowbay
Westbury, NY
I have petcocks on my block. I drain the antifreeze out in the spring and run water with WW for spring through fall
"Alcohol is for drinking, gas is for cleaning parts, and nitro is for racing!"
original author unknown, used by Gene Adams and Don Garlits among others
[Re: rebel]
#281846
04/10/09 11:59 PM
04/10/09 11:59 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
Water Wetter actually by itself doesn't reduce temps.It's really a surfactant agent.
