Original paint code for black hood #2816371
09/02/20 06:19 PM
09/02/20 06:19 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Anyone know what the black paint is called or code that was used on the mopars that came with black hoods.
Re: Original paint code for black hood [Re: mopar dave] #2816379
09/02/20 06:49 PM
09/02/20 06:49 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Huge can of worms, probably best for the restoration board.
DITZLER DDL-9355 from ppg dealer is supposed to be the right stuff.
But...........
Lots of reading here, mixed results... and in many cases managed expectations
Videos might help
https://www.youtube.com/watch?v=wZ2FkEQ_Hk0&feature=youtu.be
https://www.youtube.com/watch?v=hCqLHEozH1k&feature=youtu.be
Rich H.
Esse Quam Videri
Re: Original paint code for black hood [Re: ZIPPY] #2816399
09/02/20 07:24 PM
09/02/20 07:24 PM
Mt Morris Michigan
Mt Morris Michigan
Wow, thanks zippy. Looks like I have some reading to do, but may use a satin because I don’t want the rough texture.
Re: Original paint code for black hood [Re: mopar dave] #2816428
09/02/20 08:18 PM
09/02/20 08:18 PM
Mt Morris Michigan
Mt Morris Michigan
That stuff looks real hard to spray. I may just find something in a rattle can and spray it myself. I can’t remember what’s on my 6 pack hood, but it looks like satin black.
Re: Original paint code for black hood [Re: mopar dave] #2816488
09/02/20 09:51 PM
09/02/20 09:51 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
Sem trim black , comes in spray can , quarts or gallon
Spray can is PN 39143 , quarts is PN 39144
....BAD A$$ STREET CAR.....
Re: Original paint code for black hood [Re: n20mstr] #2816494
09/02/20 10:09 PM
09/02/20 10:09 PM
Mt Morris Michigan
Mt Morris Michigan
Does this stuff have the rough texture? I prefer smooth texture.
Re: Original paint code for black hood [Re: mopar dave] #2816594
09/03/20 10:36 AM
09/03/20 10:36 AM
N
n20mstr Offline
n20mstr  Offline
N
IT IS SMOOTH
Re: Original paint code for black hood [Re: n20mstr] #2816680
09/03/20 01:54 PM
09/03/20 01:54 PM
Mt Morris Michigan
Mt Morris Michigan
Cool. Where can I fine that?
Re: Original paint code for black hood [Re: mopar dave] #2816701
09/03/20 02:45 PM
09/03/20 02:45 PM
N
n20mstr Offline
n20mstr  Offline
N
SEM is a very popular product. Any Auto Body Jobber in your area should sell it. Look up SEM Products to see who the distributors are in your area
Re: Original paint code for black hood [Re: n20mstr] #2816705
09/03/20 02:53 PM
09/03/20 02:53 PM
Kirkland, Washington
Pacnorthcuda Offline
Anything in a rattle can is an uncatalysed paint. Not nearly as durable, if you can spray from a gun you have lots of satin, semi-gloss, semi-flat options that are catalysed and more durable for a hood.
Re: Original paint code for black hood [Re: Pacnorthcuda] #2816709
09/03/20 03:06 PM
09/03/20 03:06 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Definitely do it with a gun if you can. Much better odds of getting a nice even finish vs a paint can on such a large area.
Re: Original paint code for black hood [Re: mopar dave] #2816716
09/03/20 03:29 PM
09/03/20 03:29 PM
Mt Morris Michigan
Mt Morris Michigan
Rattle can would only be temporary. I have two painters that can get it done in my offseason. I’ll search that out.
Re: Original paint code for black hood [Re: n20mstr] #2817220
09/05/20 01:14 AM
09/05/20 01:14 AM
Mt Morris Michigan
Mt Morris Michigan
Do you know what all needs to be done to these AAR quality fiberglass hoods before painting? Can I just sand and paint?
Re: Original paint code for black hood [Re: mopar dave] #2817390
09/05/20 01:08 PM
09/05/20 01:08 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Probably needs primed and block sanded a few times to locate and fix any waviness that most aftermarket fiberglass parts seem to have.
Re: Original paint code for black hood [Re: Neil] #2817745
09/06/20 11:07 AM
09/06/20 11:07 AM
Mequon, WI
gzig5 Offline
gzig5  Offline
Mequon, WI
Mine definitely needs to be blocked a few times to smooth it out. I guess you could cheat a little if you were going with a flat finish, but it's not a hard panel to get smooth.
Re: Original paint code for black hood [Re: gzig5] #2818009
09/06/20 10:31 PM
09/06/20 10:31 PM
Mt Morris Michigan
Mt Morris Michigan
My neighbor is going to paint my hood. He paints for a living in his garage and does nice work. I am told there is a SEM paint kit that comes with every thing i need to get this hood painted. I filled the braces where i cut them, sanded and painted the bottom side with SEM rattle can satin black. Very nice paint, lays down real nice and has a nice finish when dry. Awesome paint.
