Re: MPI Fuel Injection Kit
[Re: BEINGmeISaCRIME]
#1039337
07/25/11 11:12 AM
07/25/11 11:12 AM
Posts: 13 tampa, FL
Mpi_duster
tampa, FL
How would you deal with some of the computer functions that would not be able to be used? Like the ABS system for example on an OBD-II system. Also, what do they have to convert the electronic speedometer output on the transmission to a cable driven? I would suppose some of these would have simple solutions but at the same time, it's the same thing that kept me from doing it.
From what I've heard, the magnum v8 computers weren't as tuneable as something on a mustang or something, I'm most likely wrong on that statement, maybe there's an aftermarket solution out now that could compensate. The idea of being able to have a factory style setup with lockup OD.
What is needed to fit these monsters of a transmission into a classic? I know the lengths are a bit different requiring a different way to mount the transmission at the back, what about floorpan modifications? I wonder if there would be any issues using a floor shifter as well.
PM sent.
[Re: 2fast4yourBrain]
#1039339
07/25/11 10:41 PM
07/25/11 10:41 PM
Posts: 1,130 Dayton, Ohio
wldtm
Dayton, Ohio
I think it is a great idea. However, I too have advertised this idea here in Moparts for the past 3-4 months for an OBD 1 harness that is made from and old dakota harness. See the Modern MOPAR Parts Forsale section.
I put a price on it of 300$ for harness, its wrapped, and with a PCM to go with it.
I have had interest in others making a harness they alread have, etc. but not one single offer on this harness. That is why it is currently not listed in the forsale section.
I havea 95 dakota, with a cam, intake, ported throttle body, etc and it runs on a OBD 1 harness. This truck runs at 13.60s so the misconception of having no ability to do some minor modifications is somewhat misleading.
THe option of the OBD2 harness would be the best IMO, but for me it takes more time. However, you do get the ability to use programmers which is great for a magnum 408 build etc. If you could do this harness cheap and pretty, I say this is the best option.
I have done two Magnum efi swaps with harnesses I have made in the past 3 months, and both have been great and on a very tight budget. One harness in a 68 Fury and one retrofitted into a 89 dodge dakota convertible with factory TBI. The Fury was the easier one.
I hope you can make a go of it, but I thought 300$ for a harness, relays, wrapped in powerbraid, and a PCM was a deal. Guess I am high on my price.
Got any pics of the install.
Justin
Interested in having you car wired? Drag car, street car, EFI swap?
PM for details
#1039340
07/26/11 12:50 AM
07/26/11 12:50 AM
Posts: 13 tampa, FL
Mpi_duster
tampa, FL
I'd be interested in the OBD II setup where I can control a 46RE.
You can tune the tranny? Shift points? Firmness? What else?
Even on the RE trannies to my knowledge there isn't much that can be tuned, but I haven't ever tuned one. The person to ask would be "hemifever" over at Dakota-Durango.com, he has a lot of experience tuning the magnum engines. As well as a great reputation for quality work and treating people right.
[Re: Mpi_duster]
#1039342
07/26/11 09:30 AM
07/26/11 09:30 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
I'd be interested in one for an OBDII, since I still have the MP computer from my '96 ram 5.2/5speed....only issue for me is my 318 is a LA block/mag head, so I'd have to figure out a way to mount the crank trigger.....
[Re: Mpi_duster]
#1039343
07/26/11 09:39 AM
07/26/11 09:39 AM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
Years ago, I remember reading a post from a Dodge dealership tech that said that the 1994-1995 OBD-I PCM systems had a 0 to 6 degree adjustable ignition timing retard setting that the official Chrysler DRB could set. Anyone know if this is true and where in the menu it can be applied? Is such as setting also available in the DRB menus for the Mopar Performance PCM for those 1994-1995 OBD-I years? Can a DRB-2 like this one on eBay make this adjustment? http://cgi.ebay.com/ebaymotors/Mopar-Chr...f#ht_2953wt_879After 1996 with the OBD-II PCM systems it appears that a complete 'flash' of the PCM was necessary to do ignition timing adjustments, such as the infamous 'Death Flash' applied to 5.2/5.9 V8 trucks that were pinging on 87 octane gasoline.
[Re: 360view]
#1039344
07/26/11 10:17 AM
07/26/11 10:17 AM
Posts: 13 tampa, FL
Mpi_duster
tampa, FL
I don't know much about the DRB-2, but to my knowledge the only way to program the OBD1 engines is the replace the chip within the unit.
[Re: Mpi_duster]
#1039345
07/26/11 12:16 PM
07/26/11 12:16 PM
wldtm
Dayton, Ohio
I think what the tech was refering to was the phasing of the cam sensor in the distributor. It shows 0, +1, etc.
I am not sure that this is actually controling the ignition timing directly as the PCM I think can still over rule that. (Hence the reason for the flash instead of having a tech just retard the distibutor a few degrees).
I did not mean to sound like you were saying the OBD 1 computers are not able to support functions. However, others, and myself that I have talked to always thought that OBD 1 computers would not support hardly any mods, and after buying this truck and throwing in a stock computer, I can tell you that my misconception and others is wrong.
I wanted to build a 408 with a magnum harness for my 69 barracuda, but instead went with a 5.7 hemi and factory efi.
My reason for the OBD 1 harness is it is cheap and not labor intensive to make, and you can find 94-95 dakota with a bad trans for under 500 bucks and you have almost everything you need to put a cheap efi set up in any old mopar. On both swaps I helped with, thats what the customers bought, both had bad trans (imagine that).
I would love to see your pics. PS look in the Best of Moparts Tech Archives, and there is some info on my buddies car. I think it is 5.2 in an E-body is the tite. The pictures are before we wrapped the harness.
PM for details
