Header building formula?
#2815474
08/31/20 12:28 PM
08/31/20 12:28 PM
Posts: 10,028 MN
JERICOGTX
MN
Is there an online program for figuring out the proper header size for an engine? Tried finding one, but not having any luck.
Thanks.
69 GTX
68 Road Runner
Re: Header building formula?
[Re: JERICOGTX]
#2815479
08/31/20 12:36 PM
08/31/20 12:36 PM
Posts: 13,367 Marion, South Carolina [><]
an8sec70cuda
I seem to recall a bunch of people here using Pipemax.
[Re: an8sec70cuda]
#2815498
08/31/20 01:03 PM
08/31/20 01:03 PM
Posts: 10,028 MN
JERICOGTX
MN
I seem to recall a bunch of people here using Pipemax. For $150, I'll just SWAG it... Ouch.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2815499
08/31/20 01:05 PM
08/31/20 01:05 PM
Posts: 19,367 Las Vegas
Al_Alguire
Las Vegas
Someone here has pipemax, maybe Mr P?
[Re: JERICOGTX]
#2815550
08/31/20 03:04 PM
08/31/20 03:04 PM
Posts: 4,206 New York
polyspheric
New York
Primary ID? Step? Primary length? How big is the exhaust valve?
Boffin Emeritus
[Re: LA360]
#2815724
09/01/20 01:00 AM
09/01/20 01:00 AM
Posts: 7,490 Minnesota
Hemi_Joel
Minnesota
I have pipemax but I'm not smart enuff to figure out how to open it. Bring a zip drive next time you come over.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: JERICOGTX]
#2815726
09/01/20 01:23 AM
09/01/20 01:23 AM
Posts: 31,042 Oregon
AndyF
How good do the headers need to be? If you are trying to grab every last erg of power then you'll need custom headers since none of the factory built headers have a perfect flange. If you are just building a bracket car then factory headers are fine. If you need to custom build headers for fitment reasons then factory style flanges are a decent place to start. If you want to have headers that help the engine make power then the flange and the first few inches of tubing should match the exhaust port exactly. Most off the shelf headers have a large step at the flange which kills velocity at exactly the wrong point. Get that flange correct and you've won a big part of the battle.
If you can have the first few inches of pipe off the head straight then you'll make more power. If you can use large radius bends you'll make more power. One or two step headers will make more power but cost a lot more money and time. I ran 2 inch dyno headers on my race 514 at 900+ hp even though the formula says I could've gone larger. The trick was that they matched the port very well and they were straight off the ports. The TTI headers I have on my Duster make very sharp bends right at the port. Those headers fit in the car but they cost the engine a bunch of power. Of course as Joe Sherman used to say, "I never found any power in the exhaust". Joe had more dyno pulls under his belt than most anyone in the business, header testing rarely finds much power. Power usually just gets lost on the exhaust side.
I've used PipeMax for years. It is a very useful program for a lot of reason other than header design. If you're serious about making power then PipeMax is a good program to have on hand. The cam portion of it is a little odd but the dyno prediction part of it is pretty good. I think it is built on a very solid math model.
[Re: AndyF]
#2815727
09/01/20 01:32 AM
09/01/20 01:32 AM
AndyF
[Re: AndyF]
#2815755
09/01/20 07:39 AM
09/01/20 07:39 AM
Posts: 10,028 MN
JERICOGTX
MN
I read up on that yesterday. Good info. Thanks for the other info Andy. I plan on buying my stuff through www.racemufflers.com They make different 304 Stainless flanges for BB Mopar heads.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2815776
09/01/20 09:07 AM
09/01/20 09:07 AM
Posts: 656 Florida
CJD AUTOMOTIVE
Race Mufflers is Stainless Headers out of Minnesota. They have good US stainless tubing, Rath-Gibson, and their own mandrel bending machines. I use a lot of there tubing based on the quality and price. Burns also uses Rath-Gibson. It is more expensive from them, but the bend quality is also better. Not knocking on Stainless Headers, but the the bend legs are not 100% perpendicular to the radius. That is the difference in price between the two.
Burns has an excellent program, and if you purchase tubing or a flange from them, they will run it for you for free. It is a quite an involved questionnaire about your engine, so have flow numbers, cam spec's, engine spec's, vehicle spec's, etc, available.
Craig Scholl CJD Automotive, LLC Jacksonville, FL www.CJDAUTOMOTIVE.com904-400-1802 "I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
[Re: AndyF]
#2815782
09/01/20 09:19 AM
09/01/20 09:19 AM
Posts: 1,317 Ohio
jlatessa
Ohio
Wow, is that ever a good read, thanks for the link Andy.
Joe
[Re: JERICOGTX]
#2815821
09/01/20 10:38 AM
09/01/20 10:38 AM
polyspheric
New York
W/r/t exit angle of primary: This presumes that the flange surface is actually perpendicular to the port axis, sometimes they're not. Read Blair on this, the volume, strength, and direction of both pressure waves and actual gas in a V8 exhaust is utter confusion. Many formulas end with "then make it 6" longer, and shorten by testing".
Boffin Emeritus
[Re: AndyF]
#2815894
09/01/20 03:26 PM
09/01/20 03:26 PM
moparpollack
Lil Herman
Lil Herman
85086
[Re: moparpollack]
#2816053
09/01/20 11:16 PM
09/01/20 11:16 PM
Posts: 6,142 Melbourne , Australia
LA360
Has anyone found somewhere that custom makes the megaphone for a collector? I remember finding a shop that did, but can't remember what they're called now. It wasn't the usual places like Burns, SPD, Performance Welding etc.
Alan Jones
[Re: LA360]
#2822036
09/17/20 07:53 PM
09/17/20 07:53 PM
Posts: 201 Texas
Chief
Texas
Has anyone found somewhere that custom makes the megaphone for a collector? I remember finding a shop that did, but can't remember what they're called now. It wasn't the usual places like Burns, SPD, Performance Welding etc. Is this what you are looking for? I've used them several times, good stuff. Cone EngDave
Dave Covey
[Re: Chief]
#2822046
09/17/20 08:19 PM
09/17/20 08:19 PM
LA360
Has anyone found somewhere that custom makes the megaphone for a collector? I remember finding a shop that did, but can't remember what they're called now. It wasn't the usual places like Burns, SPD, Performance Welding etc. Is this what you are looking for? I've used them several times, good stuff. Cone EngDave That's it! Many thanks!
Alan Jones
[Re: J_BODY]
#2822078
09/17/20 10:02 PM
09/17/20 10:02 PM
Posts: 10,028 MN
JERICOGTX
MN
You’re just gonna shove em out the front fender like all the cool kids anyways..... The Road Runner had fender well headers on it almost 50 years ago. I spent a lot of time and money on correcting the hack job to do that mod. No way, no how, am I cutting one single hole in that car to fit headers.
69 GTX
68 Road Runner
[Re: Chief]
#2822160
09/18/20 08:26 AM
09/18/20 08:26 AM
Posts: 5,990 Anoka County, MN
Leigh
Anoka County, MN
Has anyone found somewhere that custom makes the megaphone for a collector? I remember finding a shop that did, but can't remember what they're called now. It wasn't the usual places like Burns, SPD, Performance Welding etc. Is this what you are looking for? I've used them several times, good stuff. Cone EngDave I need to re-route one tube for steering link clearance. That link looks like the answer. Thanks!
[Re: Chief]
#2822166
09/18/20 09:13 AM
09/18/20 09:13 AM
Posts: 10,028 MN
JERICOGTX
MN
Has anyone found somewhere that custom makes the megaphone for a collector? I remember finding a shop that did, but can't remember what they're called now. It wasn't the usual places like Burns, SPD, Performance Welding etc. Is this what you are looking for? I've used them several times, good stuff. Cone EngDave Thanks for the link. I like the U bend cutting fixture. Might have to buy a couple different ones.
69 GTX
68 Road Runner
