I know this has been brought up before , but I had an idea ( I know ) and want to know if it makes any sense.
Doing an LA motor , using a stud kit for the mains , and I anticipated having to modify things around the oil pump to get the pump to sit flush on the cap.
Well , shortening the stud and the nut both will not be enough.
I put the stock main cap bolt in there , and that would need to have the head shortened for the pump to fit.
Additionally , the gap between the pump and the cap is not square.
I don't know if this is a result of the cap being cut with too much material removed form one side...........I think that is unlikely to be the whole problem ,....... the pump mounting flange being cut crooked , or a combination of the two.
I haven't measured anything yet , but the cap looks visually to be fairly even on each side.
I am considering making a spacer to lower the pump below the stud and nut , and cutting it at an angle to square up the mounting flange.
I need to pick up roughly .200 " total thickness and something on the order of .060 " difference to compensate for the angle that appears to be from one side of the mounting flange to the other.
I have access to a mill and should be able to whip up a piece that will work for me.
That and two gaskets seems like it would work on paper.
This is with a Melling HV pump.
I haven't checked the stock pump , but if the rotor section is thinner , I could try that too and maybe solve one of the issues I am looking at here.
Thoughts ?
