Aftermarket Kickdown & Throttle Cable Setups #280765
04/07/09 07:39 PM
04/07/09 07:39 PM
Middle of A Field
O
OrangeProwler Offline OP
O
Middle of A Field
I've seen Lokar, XVMotorsports, and Bouchillon Performance. Just wondering which one is the best? I've been leaning the way of the Bouchillon one but, wanted to see if the others were any count or the Bouchillon is one to mark off of the list. Thank you in advance.
Re: Aftermarket Kickdown & Throttle Cable Setups [Re: OrangeProwler] #280766
04/07/09 07:54 PM
04/07/09 07:54 PM
North Dakota
440abody Offline
440abody  Offline
North Dakota
I have used both, the Lokar and the Bouchillon.
I think the Bouchillon Performance one is by far the better product. It's way easier to tune to your set up and installation is a snap. The Lokar although some will say it's a good piece, I however didn't have much luck with it. I am using Lokars throttle cable, which was very easy to install and been trouble free.
73 Dart Swinger 440/727 8.75 w/3.55's
34 Ford 3w coupe with a soon to be 1958 392HEMI!
