Vapor Separator? #280681
04/07/09 06:57 PM
04/07/09 06:57 PM
IL
71383beep Offline OP
IL
In the process of getting my car ready for this season and I thought that I would tackle the latest wierd issue i had with it last year.
It ocasionally would have very hard starting issues after sitting for a half hour or so after a good drive. It almost seemed like it was flooded. I would have to floor it to get it started, but sometimes even that would not help. I would crank and crank and then let it sit for 30s and then she would fire up.
I was thinking vapor lock, but the carb has a phenolic spacer and the line is AN from the pump to the carb and not near the headers.
Someone recently sugested that I install a vapor separator. I have the 5/16 inch vent line for it, but it goes to the evap contraption behind the left wheelwell and the 5/16" nipple on the tank is capped. This is a CA car if that matters and I have the 3/8" steel fuel line.
I do suspect a venting issue though too because when i pull the fuel cap to put gas in there is a ton of back preassure which I know is not good.
Will a properly installed vapor separator resolve these issues?
'73 GK6 Challenger Rallye - 340 4-Speed
Re: Vapor Separator? [Re: 71383beep] #280682
04/07/09 07:03 PM
04/07/09 07:03 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
What car? Your 71?
Re: Vapor Separator? [Re: Challenger 1] #280683
04/07/09 07:25 PM
04/07/09 07:25 PM
IL
IL
Yep,
71 charger Super Bee - 383 auto.
Re: Vapor Separator? [Re: 71383beep] #280684
04/07/09 08:10 PM
04/07/09 08:10 PM
Cincinnati, Ohio
Cincinnati, Ohio
To do it right, you need three fuel lines. One for feed, one for the return from the vapor separator. Both of these connect to the sending unit. The third goes from the valve cover breather to the rear of the car to the tank vapor separator in the trunk. This is how my N95(Cal) 71 E body is layed out. I'm not sure about your car but I'm thinking it is the same. I am sure you want your vapor separator returning to the sending unit. And yes it does work because I have two cars setup this way and drive with AC on in the hottest weather.
Here's two of them, I haven't added the third fuel line yet in this picture.
Vapor separator that goes in the trunk.Notice how it has 5 nipples on it and the tank only has 4 vapor hoses.
Third line in place that goes from the VC breather to the rear separator.
And then you know where the V.S. goes up front right? Be sure to check that it has a #54 or so size hole for the return too. There was some bad ones out there I heard with no restriction in the return.
That's where it goes on the motor(fuel pump bolt)
Re: Vapor Separator? [Re: 71383beep] #280685
04/07/09 09:25 PM
04/07/09 09:25 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
You should try a new gas cap first, IMHO. Gas caps are designed to allow air in when too much vacuum is present or too much pressure is present, and from your description, it sounds like the cap isn't releasing the excess pressure. Gas caps seem to be one of those parts which most people never replace, but they do wear out.
Re: Vapor Separator? [Re: Challenger 1] #280686
04/07/09 09:28 PM
04/07/09 09:28 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
'71-'72 B-vans used a similar system (four vent tubes originating at each top fuel tank corner, all leading to the vapor separator), with the fifth line from the separator leading to the carb, where excess vapor is drawn in and burned.
Re: Vapor Separator? [Re: In_The_Pink] #280687
04/07/09 09:33 PM
04/07/09 09:33 PM
Cincinnati, Ohio
Cincinnati, Ohio
Very good point
I forgot to mention, Have you ever removed the gas cap and see if it makes a difference?
But nothing should be "capped off" on your fuel system for it to work right.
Re: Vapor Separator? [Re: 71383beep] #280688
04/07/09 11:22 PM
04/07/09 11:22 PM
Kenosha, WI wi/il border
BobN Offline
BobN  Offline
Mega Parts has them
608-452-2045
or Paddackcalso
Re: Vapor Separator? [Re: BobN] #280689
04/08/09 09:52 AM
04/08/09 09:52 AM
New Hampshire
W
whitemtnelf Offline
whitemtnelf  Offline
W
New Hampshire
The vapor canister near the gas tank on my '71 Charger is rotted out. Is this something that I have to replace or can I get by without it?
Re: Vapor Separator? [Re: whitemtnelf] #280690
04/08/09 10:42 AM
04/08/09 10:42 AM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Is this the vapor separator you were asking about?
Re: Vapor Separator? [Re: Snoopy] #280691
04/08/09 10:47 AM
04/08/09 10:47 AM
New Hampshire
W
whitemtnelf Offline
whitemtnelf  Offline
W
New Hampshire
No. The one that I'm referring to is mounted behind the left rear fender and has about 4-5 lines attached to it.
Re: Vapor Separator? [Re: whitemtnelf] #280692
04/08/09 11:24 AM
04/08/09 11:24 AM
Snoopy Offline
Snoopy  Offline
This is from the 70 FSM and shows the typical ECS setup.
Re: Vapor Separator? [Re: Snoopy] #280693
04/08/09 01:49 PM
04/08/09 01:49 PM
IL
IL
Thanks guys all very helpfull.
I have this setup on my charger with the large separator behind the fender. It has 5 lines going to it. 4 from the tank and the one 5/16" hard line I currently have. I have that 5/16" line connected to my 3 nipple breather cap, but since I am running an aftermarket carb there is no vent provision to go to the breather. I always wondered if the carb vent line actually provided the vacum to run the system? If so couldn't I just tie into the manifold vacum PCV or power brake line with a T?
I am looking at the system Challenger1 is sugesting and thanks for the pictures. Even though it's an ebody I understand what it's doing. I did not realize that there was a 3rd line. So it looks Like I would actually need a return line which would go from the front vapor separator canister and go to my capped 5/16" nipple on the sending unit. It looks like my pretty Braided line from the pump will have to go...back to rubber hose I guess. I guess I was wondering if the aftermarket has come up with anything i could use the AN lines on.
The cap is actually a newer replacement one from Stant. It is VERY tight. I would usually drive around with it cracked a bit off, but i still had the starting problems.
I think I'll pull that large separator this weekend and see ifits full of gunk or something. Anyone ever take one of these apart? From the FSM it just looks like tubes set at various elevations. To me it doesn't make sense for me to have a vacum if this think was working and I had a tight cap. If this vapor thing vented to air I should not get a vacum. Right?
Re: Vapor Separator? [Re: Snoopy] #280694
04/08/09 02:07 PM
04/08/09 02:07 PM
weymouth,mass.
meepmeep70 Offline
meepmeep70  Offline
weymouth,mass.
not to highjack,but can we post a diagram for 70 road runner 440? i'm buying new tank this week,my old tank had the vent running up into the trunk and back out,only one line ran up to the fuel pump,do i need to run two lines up front and install a vapor seperator? back when the second third tube came off tank to 6"hose with a bolt in it .thanks for your help,and sorry to highjack ,it was kinda similial question
Re: Vapor Separator? [Re: 71383beep] #280695
04/08/09 05:10 PM
04/08/09 05:10 PM
Shoreline, Washington
72roadrunnergtx Offline
The b-bodies in 71 thru mid-year 72’ had the fuel tank vapor separator located in the driver’s side rear wheel well. The hard line running up to the breather cap in 71’ is the tank’s vent line. Any fuel vapors evaporating from the tank while the car was at rest would be collected in the crankcase to be consumed at next start up via the PCV valve. Any vacuum present in that line would be equal to that of the crankcase while running nothing more.
Mid–year 72’ had a redesigned tank vapor separator much smaller and located just forward of the tank. Enclosed carb bowl vents in 71’also connected to the breather cap for the same reason. 72’ had these evaporative lines connected to the charcoal canisters.
Not to be confused with the fuel supply line vapor separators that were installed to resolve vapor lock conditions on some big-block/California cars and as mentioned required a return line.
72 1/2' and up vapor seporator
Try leaving the air cleaner off while as it sits hot for the 30mins, see if it starts any better.
Quite a few six-packs suffer from vapors evaporating/collecting in the air cleaner after a good heat soak condition making for an over-rich hot start-up within a window of about 15min to about an hour or so. The combined surface area of the fuel in the 3 bowls contributes to a higher than average evaporation rate.
1972 Road Runner GTX 440 6bbl 5-speed
[img]http://72rrgtx.com/carpics/bucket/DSC06730r-1.jpg[/img]
Re: Vapor Separator? [Re: 72roadrunnergtx] #280696
04/08/09 05:42 PM
04/08/09 05:42 PM
IL
IL
Excellent!
I think you guys are onto something. To clarify though this is a september 1970 build Super Bee so it is a very early model. I definately don't have a charcoal can nor the additional evap contraption on the tank.
So If I am intepreting this correctly...the fuel tank separator is probably correctly working. I have correctly connected it's vent line to the 3 nipple breather. The breather's vacum is through the crankcase so that is not an issue. The pluged nipple on the breather is for my carb bowl vent line which I don't have so that is not an issue. Is there a differnce which nipple is used BTW? Do you have a photo?
SO my issue is most likely caused by a lack of having a stock style vapor separator that went underneath the alternator and returned to the capped 5/16" line on the tank. So I need a vapor separator and 5/16" return line. Correct?
Is this in any way related to the vacum issue with the gas cap? I thought all modern gas caps don't have a vent because they kill polar bears or something?
Re: Vapor Separator? [Re: 71383beep] #280697
04/08/09 06:04 PM
04/08/09 06:04 PM
The three nipple breather; tank vent line would connect to a 5/16”nipple. Bowl vent line is 3/8” and the air cleaner hose is something like 7/8”.
BTW a vapor lock condition would lead to fuel starvation at the carb not the flooded condition I interpreted from your first post.
The smaller tank vapor separator pictured above for 72 ˝’ replaced the one you have in the LR wheel well.
Re: Vapor Separator? [Re: 72roadrunnergtx] #280698
04/08/09 06:20 PM
04/08/09 06:20 PM
IL
IL
Thanks for the picture. I know I got it backwards. I caped thelower 5/16" line and conected the vent to the upper 3/8" nipple. Could that cause anything?
If the vapor separator is not the cause then what would help my hard starting issue?
Re: Vapor Separator? [Re: 71383beep] #280699
04/08/09 10:54 PM
04/08/09 10:54 PM
If it were me, I’d been looking at the carburetor for internal leakage. If you’re running a Holley, possible causes can be metering block gaskets, warped metering block and or main body. Power valves can develop pin hole leaks in their diagrams. Anything allowing fuel to slowly drip into the manifold would create hot start issues and may not be noticeable at all on cold starts.
Re: Vapor Separator? [Re: 72roadrunnergtx] #280700
04/09/09 10:35 AM
04/09/09 10:35 AM
New Hampshire
W
whitemtnelf Offline
whitemtnelf  Offline
W
New Hampshire
My fuel/vapor separator is totally rotted out. Can I get away without using it or do I have to find one that's in decent shape?
