Re: Decarbon running engine?
[Re: GMP440]
#2804818
08/03/20 11:11 PM
08/03/20 11:11 PM
Posts: 1,757 Phila
PhillyRag
Phila
What I did that worked years ago is to connect rubber tubing from the washer reservoiur motor to the carburetor opening and attach above the throttle plates. Fill the reservoiur with water and run the car on the highway. Every few seconds hit the windshield washer button to spray water down the carb. This works because you are decarbonizing the piston tops when the engine is under load full temperature..
Sounds feasible: guessing you'd want some sort of smaller small hose/spray type nozzle at the carb end. Don't want to inject a "gulp" of water each shot.
[Re: maximus]
#2804859
08/04/20 08:02 AM
08/04/20 08:02 AM
Posts: 4,923 new berlin wisconsin
Mr T2U
i remember when we were still a GM dealer. someone brought in a C3 corvette that was owned by a older person who only putted around town with only short trips so it never really warmed up. the new owner tried driving it like he stole it but had a pinging problem like you describe. the driveability tech used some GM top end cleaner. he got the car HOT. then removed the vacuum line for the brake booster and stuck it in the can. he reved it up and it sent out a big black cloud out the exhaust. after he emptied one can he took the second can and did the same but not rev it up so much. the car quickly died. after it died he poured the rest down the intake, he killed the coils and cranked it over while pouring. and let it sit overnight. the next day he fired it up again, it smoked like crazy. he ran it until the additive cleared out. he changed the oil and the problem was gone.
perception is 90% of reality
[Re: PhillyRag]
#2804926
08/04/20 10:17 AM
08/04/20 10:17 AM
Posts: 1,637 Florida
GMP440
Sounds feasible: guessing you'd want some sort of smaller small hose/spray type nozzle at the carb end. Don't want to inject a "gulp" of water each shot. I actually used the same windshield washer resorvoir hose from the washer pump to the carburetor. No spray nozzle was used. It worked well. If you want to put a spray nozzle at the end of the hose; maybe go to Lowes or Home Depot and buy a misting nozzle that's used for outdoor sprinkler systems to water shrubs. The misting nozzle line attachment is about the same diameter as the washer hose.
[Re: maximus]
#2805027
08/04/20 02:24 PM
08/04/20 02:24 PM
Posts: 8,326 fredericksburg,va
cudaman1969
fredericksburg,va
Old trick we used in the 1960's and 70's. Start up the engine and let it warm up a little, slowly pour about a cup of transmission fluid down the carb. You will see smoke come out the back, shut engine off quickly and let set for about 20-30 minutes. Restart engine and rev it up a little, hitting the pedal a few times until the exhaust clears up. It has cleared a lot of carboned up engines back in the day when lead was in the fuel plugging the cylinder heads. I've seen chunks of carbon blow out, back in the day. Did the same only used a whole quart (Not synthetic) and ran it at 2500 rpm (never turned off) till it stopped smoking.
[Re: PossessedDuster]
#2805089
08/04/20 04:07 PM
08/04/20 04:07 PM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
Mopar’s official brown foaming spray has worked very well for me, including on heavily carbon’ed up EGR passageways. It makes a huge cloud of black smoke. https://www.morris4x4center.com/mopar-combustion-chamber-cleaner-13-oz-aerosol-can-4318001ad.htmlAs an experiment many years ago I used a second pcv valve to suck ac conditioner drain water into the intake manifold of a 1995 Magnum 5.9 V8 for over two Summer months. This made an odd noise in the passenger compartment of the pickup, slightly lowered city MPG, but did clean carbon off the tops of pistons.
[Re: maximus]
#2805202
08/04/20 09:12 PM
08/04/20 09:12 PM
Posts: 1,757 Phila
PhillyRag
Phila
Old trick we used in the 1960's and 70's. Start up the engine and let it warm up a little, slowly pour about a cup of transmission fluid down the carb. You will see smoke come out the back, shut engine off quickly and let set for about 20-30 minutes. Restart engine and rev it up a little, hitting the pedal a few times until the exhaust clears up. It has cleared a lot of carboned up engines back in the day when lead was in the fuel plugging the cylinder heads. I've seen chunks of carbon blow out, back in the day. It has detergents in it to keep valve bodies clean. Also was a 1/2qt substitute during an oil change for sludge.
[Re: Mr.Yuck]
#2806138
08/07/20 12:55 PM
08/07/20 12:55 PM
Posts: 28,606 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
I saw an old guy who was a drunk do that He used a Beer. He says One for me and One for the car. It did work but only cleaned one of them up CONSIDER a mild water injection system ... clears EVERYTHING up I remember my dad taking the garden hose out to his 71 Cutlass, he started the engine up, let it warm up, then he rev'd the motor up, probably 4000rpm and turned the hose on... I was like WHAT are you doing. he said cleaning out the carbon, today's gas is junk. Well you should have seen the mess coming out the tailpipes. Car ran like a top.
