Page 3 of 3 1 2 3
Re: Worn out engine - WWYD? [Re: Guitar Jones] #2805720
08/06/20 12:08 PM
08/06/20 12:08 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Originally Posted by Guitar Jones
Originally Posted by not_a_charger
The pan is still off.
No brainer then. Roll in new bearings, seals, oil pump and a timing set. Enjoy.
Back in 2003 my father was in a Florida campground for the month. He was in his 5th wheel camper. His 89 chevy pickup he pulled it with lost oil pressure. Another retiree buddy in the camp ground who was a handy guy dropped the pan and did the bearings seals and oil pump on the grass/dirt ground. Truck ran great and he sold it in 2005 still running great.
Keep old mopars alive.
Re: Worn out engine - WWYD? [Re: NITROUSN] #2805910
08/06/20 08:08 PM
08/06/20 08:08 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Originally Posted by NITROUSN
D] Roll a set of bearings in it along with a new oil pump and drive it.
iagree
Re: Worn out engine - WWYD? [Re: TJP] #2805967
08/06/20 10:27 PM
08/06/20 10:27 PM
NE OHIO
K
kevin69bman Offline
kevin69bman  Offline
K
NE OHIO
Mike
What shop has the truck /? are the good and can just put bearings in it like said if so that's what we did back then and only the mains and seal
Re: Worn out engine - WWYD? [Re: not_a_charger] #2806738
08/09/20 05:09 AM
08/09/20 05:09 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
10w30 has no place in an old worn engine unless you can confirm the oilpressure is still good.
20w50 oil should have been put in it a long time ago.
Since you have the pan of anyway, now is the time to change the bearings, as long as the journals don't have deep grooves in them.
A timing kit and a HV-oilpump will bring many more years in an engine.
Re: Worn out engine - WWYD? [Re: not_a_charger] #2807476
08/10/20 09:42 PM
08/10/20 09:42 PM
SoCal
Frank Cannon Offline
SoCal
I'd fix it, that's a good looking truck.
CALIFORNIA-SUNDAY-10:04 A.M.
Re: Worn out engine - WWYD? [Re: not_a_charger] #2807502
08/10/20 10:45 PM
08/10/20 10:45 PM
n.c.
geo. Offline
geo.  Offline
n.c.
Thought about that, but the engine has 189k on it. I'm concerned I'd be throwing good money after bad if I did that.
I don't understand your answer, bearing replacement is your cheapest out.
How many miles per year do you drive this truck?
How much longer do you hope to drive it?
What is the primary use of the trunk?
Re: Worn out engine - WWYD? [Re: geo.] #2807629
08/11/20 11:37 AM
08/11/20 11:37 AM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
Would you do rebuild yourself? I didn't see it if you mentioned it.
If you are doing it yourself, I'd do a complete rebuild too, other than sending out for machine work. You know it'll be assembled right, save money, and won't leave you stranded. The truck is solid. If you're not doing the work yourself, I might just drive it until it dies.
Facts are stubborn things.
Page 3 of 3 1 2 3
