Re: Making a 1500 Ram tow a 24 footer ? ....
[Re: dOrk !]
#2795589
07/11/20 07:39 PM
07/11/20 07:39 PM
Posts: 30,424 Florida STAYcation
dOrk !
The village idiot's idiot
Florida STAYcation
27 views and no ? OF COURSE it would have a 5.7 !
[Re: gtx6970]
#2795626
07/11/20 10:08 PM
07/11/20 10:08 PM
Posts: 10,559 Freeport IL USA
poorboy
Freeport IL USA
what kind of truck ? what kind of trailer ? And: How far? How often? What is on or in the trailer? Trailer weight loaded? The short answer is turn the 1500 into a 2500 or better yet, a 3500. Gene
[Re: redraptor]
#2795700
07/12/20 07:39 AM
07/12/20 07:39 AM
Posts: 43,545 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
I towed my 24' and 29' enclosed trailer with my 2000 Ram 1500 4x4 5.9 gas and it was adequate. If you are talking a modern Ram, there is absolutely no issue towing a 24' nowadays, it will be more than adequate. Check out the specs, they tow almost twice as much weight as the old trucks...
JB Rhinehart, Realist
A-Body's RULE!
[Re: earlymopar]
#2795736
07/12/20 09:46 AM
07/12/20 09:46 AM
Posts: 2,110 Byron, NY
W.I.N. Racing
Byron, NY
Although the 1500 as stated above is capable (spec wise) it will depend on the amount of use. Towing a trailer stress's the frame more than not towing a trailer - obviously, so a 1500 frame being less robust than a 2500/3500, the number of miles annually you plan to tow should be your guide (more miles more truck). Additionally power to go is one thing, power to stop is another and the ability of the truck controlling the trailer improves with truck size. With a 1500 your approaching a Tail wagging the Dog scenario on the bad end of the spectrum. Meaning, few if any enclosed trailer loaded weigh lees than the truck pulling them. As the truck capabilities increase so does the sub systems like tires, Wheels, U-joints, transmissions, rear ends. For instance, a dually pulling a 24ft trailer is much easier on everything (truck and driver) than even a 2500 and especially a 1500. But a 3500 dually is not practical for most people. When you go into a curve with a dually it is a much more comfortable feeling than a single rear wheel truck. Aggravate that with a tire typically found on a 1500 and it gets worse. I'm not saying get a 3500 I'm saying think about what your really going to be doing, short trips 25-30 mi a weekend a 1500 should be fine. Traveling 100's of miles regularly get a bigger truck or smaller trailer and enjoy the trip. As support of my thoughts I've towed using a bunch of methods - Tow bared my first race truck from Roch NY to Reading Pa -320mi, with a /6 stick Van (read as Young and dumb), upgraded to a 21'open trailer and a "Job rated" D150. A D300 Ramp truck, D350 and 3500 and a 36" Enclosed Gooseneck and Now a 3500 and 53' Gooseneck. Of all of those combinations the 3500 and 36' goose was the best (all things considered). I am now in the midst of getting a bigger truck, The 3500 pulls the 53" but very close to the "Tail Wagging the Dog" scenario I spoke of prior. There's my make of it what you will.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: mgoblue9798]
#2796281
07/13/20 07:17 PM
07/13/20 07:17 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
I tow a 16 foot car trailer with my 2011 ram 1500 6.4 hemi all the time, the 20" load range E tires made a huge difference in the tail wagging department, I don't even think about that any more. That is the only change I have done, I wish I could find some hard rubber bushings for the rear control arms but only found them in an expensive adjustable complete assembly but now with the 20" wheels tires I don't think that is a huge deal now.
[Re: 5thAve]
#2796521
07/14/20 01:28 PM
07/14/20 01:28 PM
HotRodDave
Kalispell Mt.
yeah the factory says and does a lot of weird stuff but it tows way better now.
[Re: HotRodDave]
#2796871
07/15/20 10:48 AM
07/15/20 10:48 AM
Posts: 4,979 new jersey usa
11secdart
new jersey usa
I tow my 20 ft Haulmark with My Dart and sometimes my 92 D150 all over the place with my 08 H.Q.C. 1500 4x4 . 3.91 gear , I installed a cold air intake and cat back exhaust and it really woke it up, I was tempted to install an aftermarket programmer but the H.P. gains were't enough to justify the cost. Also I tow in O/D off mode less shifting and more power than in trailer tow mode.
