thanks dave ! it's not like this thing is going to be run a ton of miles, but it will be beat on occasionally.
it also has compression [11.5 : 1] and a choppy SFT cam [268 @ .050] with good springs, so a good oil is a must.
the question was asked because i don't know what weight engine oil was used, [although i know for sure it was amsoil] but i know amsoil "super shift" transmission fluid was used because i got an empty bottle. i didn't know they made that.
i also was trained to believe synthetic transmission fluid was not so good on the clutch packs, so
i was thinking of changing over to my old standby, type F.
i have been so long without having a running hotrod. i have tried to keep up, but my old mind keeps forgetting what i have tried to keep up on !
