AGM battery charging ?
#2789377
06/26/20 10:05 AM
06/26/20 10:05 AM
Posts: 19,587 north of coder
moparx
i just "inherited" an AGM battery that has been dead for a long time. it is a durecell ultra platinum 60ah, 600cca, group 24 size. it now shows on my dvm .07 volts. can this be brought back ? i don't have a charger for AGM batteries, although i have considered buying one for quite a while. the only charger i own is an old shumacher 2-10 amp charger. if i can use this charger coupled to a regular type battery, how discharged should the regular battery be ? or am i wasting my time trying to bring this AGM back to life ? TIA graciously as always !
Re: AGM battery charging ?
[Re: AndyF]
#2789424
06/26/20 11:55 AM
06/26/20 11:55 AM
Posts: 8,032 Tulsa OK
Bad340fish
Tulsa OK
The Optima Chargers are great, that is what I own at home and I have been in the battery business for a long time. AGM or not prolonged periods of lack of use do not do a battery any good, at .07 volts its pretty much a brick at this point. Its not impossible that it will charge up, but unlikely.
68 Barracuda Formula S 340
[Re: moparx]
#2789442
06/26/20 12:33 PM
06/26/20 12:33 PM
Posts: 43,607 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
I am currently trying to charge an Optima battery that requires a regular battery in series with the Optima. Sometimes I have luck doing it that way, sometimes I don't. All in all I HATE Optima batteries. I don't have enough of them laying around to justify buying a another charger just for Optima's...
JB Rhinehart, Realist
A-Body's RULE!
[Re: Rhinodart]
#2789452
06/26/20 12:45 PM
06/26/20 12:45 PM
Posts: 20,886 A collage of whims
topside
A collage of whims
The newer (last few years) Schumacher triickle/maintainer chargers work with anything. Used one on a couple Optimas I had. Roundabout $25. I also replaced an ancient 40A charger with a new Schumacher, charges/boosts anything, think it was about $70. Kinda depends on how big a hurry you're in
[Re: topside]
#2789485
06/26/20 01:31 PM
06/26/20 01:31 PM
moparx
The newer (last few years) Schumacher triickle/maintainer chargers work with anything. Used one on a couple Optimas I had. Roundabout $25. I also replaced an ancient 40A charger with a new Schumacher, charges/boosts anything, think it was about $70. Kinda depends on how big a hurry you're in hurry ? what's that ? i couldn't hurry if i was being chased by the guy with the pitchfork ! maybe a new style schumacher would be worth investigating. the one i have now was bought around 1974 or so, and it still works ! if their quality is only half as good as it was back then, it will be the last battery charger i'll ever buy !
[Re: moparx]
#2789581
06/26/20 05:19 PM
06/26/20 05:19 PM
Posts: 20,660 in a cattle trailer down by th...
Guitar Jones
I won't waste my money on an AGM battery let alone a special charger for one. They don't last any longer than a lead acid battery and cost 3-4X as much. Not worth it in my eyes.
[Re: moparx]
#2789784
06/27/20 09:27 AM
06/27/20 09:27 AM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
At 0.07 volts there is not much chance that old AGM would ever be useable. I have owned one of these 4 amp chargers for 5 years and believe it works somewhat https://www.pulsetech.net/store/12v...tery-maintenance-charger-desulfator.htmlI wish it had another led light for 90% Charge level between the 75% and 100% leds that are provided. Pulsetech claims they do not use simple voltage to judge percent charge, but “charge current acceptance” which I take to be similar to impedance. It takes a long time to go from 75% charge to 100% sometimes 36 hours. I put a $21 Kill-A-Watt power meter on it to get a better sense of how things are going. https://en.wikipedia.org/wiki/Kill_A_Watthttps://www.pondliner.com/kill-a-wa...q2I6i6gIVc-W1Ch05YA3oEAQYAyABEgL29vD_BwENo load it consumes 2 watts. When starting to charge a lead acid battery that was below 12.3 static voltage the Pulsetech will use 48 watts and the led for 25% charged will light. When it gets to 100% charge it will show 4 watts being consumed by the Powetech. When the Powertech is charging a battery an AM radio will have a lot of radio frequency interference (RFI) buzzing noise at 530 kilohertz.
[Re: Mr T2U]
#2789845
06/27/20 12:31 PM
06/27/20 12:31 PM
moparx
please don't get me wrong guys. i'm NOT going to buy an AMG battery, i was just wondering if this battery i had given to me could be re-charged. and the fact the charger i own now is so old, i MAY be considering purchasing a new charger. very insightful comments so far. thank you !
[Re: moparx]
#2790200
06/28/20 07:29 AM
06/28/20 07:29 AM
Bad340fish
Tulsa OK
Like I said before the Optima charger is great. I just have the small 4 amp one and love it.
