Re: 73 W100 Drivetrain vibration
[Re: northcoastmopar]
#2788349
06/23/20 07:59 AM
06/23/20 07:59 AM
Posts: 18,423 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
Cool thanks...yes, phased is probably the better word than parallel. Take pics of each of the u-joints and try to do so at the same orientation? If possible try to get a complete picture including the yokes of each shaft. The intermediate or jack shaft is the one I would like to see
[Re: NITROUSN]
#2788368
06/23/20 09:25 AM
06/23/20 09:25 AM
Posts: 4,366 Cleveland, Ohio
northcoastmopar
Cleveland, Ohio
Cool thanks...yes, phased is probably the better word than parallel. Take pics of each of the u-joints and try to do so at the same orientation? If possible try to get a complete picture including the yokes of each shaft. The intermediate or jack shaft is the one I would like to see Got it. Will grab pics tonight. Thanks!
[Re: buildanother]
#2788415
06/23/20 11:11 AM
06/23/20 11:11 AM
northcoastmopar
Cleveland, Ohio
If the splined yoke has never been slipped off of drive shaft, it all should be fine. I learned that long ago because some shafts do not have that double key that only lets the two go back together one way. If you index it any way you want, there will be huge bad vibes. I have no idea regarding the history of this truck. The seller fibbed and omitted a lot of things so I don't know what's original or been monkeyed with.
#2788434
06/23/20 12:06 PM
06/23/20 12:06 PM
Posts: 2,113 Byron, NY
W.I.N. Racing
Byron, NY
Id start with correcting the phase angle (new U joints as long as your there)
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: NITROUSN]
#2788738
06/24/20 08:54 AM
06/24/20 08:54 AM
northcoastmopar
Cleveland, Ohio
NITROUSN -
Thanks...ugh...another clear example of why not to buy a vehicle from across the country without inspecting in person. A drunken eBay purchase....
I'm assuming this is the type of jackshaft I need if I had the correct short tail trans? I can check FSM when I get home but do you know model number of correct tail trans I need? I assume these are a little hard to find and I have to decide whether I want to sink the cash or just part ways. It's a shame, because it's a cool truck. 99% rust free, 400bb, a/c, cruise, two tanks, camper package...etc.
I will probably mess with it removing the front driveshaft and getting pics of the trans mount tonight...grrrrr.......
