Re: Dual Quad Intakes [Can you disconnect one carb?]
[Re: SCATPK]
#278717
04/05/09 10:32 PM
04/05/09 10:32 PM
Posts: 699 Cooperstown, NY
jrlegacy23
Cooperstown, NY
Can't you just block the secondaries of both carbs so the you are still using both carbs but only the primaries?
[color:"#00FF00"]68 Fastback Barracuda with some stuff[/color]
[Re: SCATPK]
#278718
04/05/09 10:51 PM
04/05/09 10:51 PM
Posts: 2,511 Tampa , Fl
MoparJoe
super gas
super gas
Tampa , Fl
With stock linkage it should just be running on the rear carb at cruise speed, 10mpg is about right as it takes a lot of fuel to keep those ports happy.
A local guy I know with a 70 GTX gets about 10-12 out his at best, it's around 450" 12-1 comp, solid roller, MP aluminum heads, stock manifold & 2-600 edelbrocks- rear carb has an electric choke, 727 w/2,700 stall & 3.54's. 10-12 is straight hwy w/29" street tires, if he has 28" drag radials on it drops and if he romps it his avg mpg goes to 4-5. It's not built for economy he just tracks MPG since it will go thru a tank of gas in 2 hrs cruising around.
[Re: Dallasdart]
#278723
04/06/09 12:53 AM
04/06/09 12:53 AM
Posts: 6,570 San Francisco Ca
SCATPK
San Francisco Ca
Trust me my carbs are set up correctly and they are one to one.
Not meant to be rude but what kind of MPG are you expecting?
I have a wide band A/F gauge plumbed into the header and I am fat at cruise about 11.3 -11.7 and I should be about 12.8 with my setup. I bet with some tuning I can sqeeze 12mpg out of it on a nice steady highway cruise.
[Re: SCATPK]
#278724
04/06/09 05:35 AM
04/06/09 05:35 AM
Posts: 1,796 Greer, SC
TooMany62s
Greer, SC
If you're running an in-line intake and the linkage is set up like this, it will be progressive and the front carb will only function when you put your foot in it. You can remove the link and leave the front carb off completely.
[Re: RUNCHARGER]
#278726
04/06/09 12:31 PM
04/06/09 12:31 PM
Posts: 4,573 ...gently down the stream
LAR_414
Listen up people.....an ENGINE needs a certain A/F ratio to run properly. It doesn't care how it gets it. Dual Quads set up properly are just as fuel efficent as a 2brl carb, which can be just as fuel efficent as fuel injection.
An A/F meter (LM-1) is the best way to tune things and get the ratio correct for all driving situations (cruise, idle, accel pumps, wot,.....)
TO answer your question, OF course you can disconnect one carb, and re-adjust the IDLE SPEED SCREW. You (theoretically) should not need to adjust the idle mix screw. But that's a bid too perfect, as you will start getting into the transition circuit, the more you open the blades up.
But you are just masking the problem here......Get the Carbs setup and you'll be just as efficent as a 2brl!
[Re: LAR_414]
#278728
04/06/09 12:51 PM
04/06/09 12:51 PM
Posts: 4,179 California
mickm
California
i have the stage V also, with 2 650 eddy's. i also get lousy milage, but with a 472 running 1 to 1 on the carbs, i'm not sure i can expect much else.
i have talked with tim banning at FHO, and with the guy, (can't remember his name), at stage V who makes the manifold and they both say run it 1:1. now, i never did ask about mileage, so maybe that is another issue.
i assume though that if you could get better mileage, the same power, and not run the front part of the engine lean, they would have said so. would be worth double checking and asking that.
herb, do you have your vacuum advance set up? that would obviously help on the highway. although i have never checked actual mileage, i did seem to notice a difference when i got mine coming it at the right time.
[Re: SCATPK]
#278729
04/06/09 01:04 PM
04/06/09 01:04 PM
mickm
California
He asked why not disconnect one carburator when you are just cruising around for better mileage and I said I am not sure that it can be done but would ask the question? Can this be done without any ill effects?
besides, you know you would only be frustrated at not being able to lay into it when and where you want to
[Re: mickm]
#278731
04/06/09 02:39 PM
04/06/09 02:39 PM
Posts: 322 Itasca, Texas
Mad_Scientist
Itasca, Texas
I wish there were some prices listed. I have been thinking of getting a Hemi, but remember reading about these heads years ago. How much did a complete set of heads run you guys?
69 Super Bee 440 5-speed 70 Dart Swinger 340 4-speed 69 Camaro SS 396 4-speed 66 Cutlass Convertilbe 70 Judge Ram Air III 4-speed 68 F-100 SWB
[Re: Mad_Scientist]
#278732
04/06/09 02:58 PM
04/06/09 02:58 PM
mickm
California
that depends on what you want. out of the box i think you can get them or around $2k. fully assembled, ported, valve job, etc... you are looking at close to $4k from FHO.
depends if you have a rocker assembly, or if you want theirs.
they are not cheap, but well ported ones can flow as much as 440 cfm on the intake. that is the street version, with 2.25/1.90 valves.
[Re: RUNCHARGER]
#278733
04/06/09 08:21 PM
04/06/09 08:21 PM
SCATPK
San Francisco Ca
Herb: Are you running a Stage V intake? The stock intake obviously works with the progressive linkage but the Stage V is a single plane design.
Sheldon
Sheldon, I am now running a Stage V intake swapped it out for the factory unit. As for the A/F ratio I was advised by Tim at FHO not to run it more that 12.8 A/F at cruise to avoid any lean condition issues. Anyone on the board running a big cube hemi with a stage v intake with a leaner ratio without issue?
