Re: Epoxy or j-bweld or steel stick
[Re: rickraw]
#2785617
06/15/20 09:53 AM
06/15/20 09:53 AM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
What’s best to use on cast aluminum valve cover. I have to close off 3 sides of a baffle. Don’t want what ever I use to fall off. Thanx. Myself I would redo the baffle but the stick would be thicker and stay where you put it and metal prep would be key on all.Do you want to use an oil restrictor in the heads ?
