New Best ET
#2782556
06/07/20 09:38 PM
06/07/20 09:38 PM
Posts: 4,696 On the parachute mount
n20mstr
Went to Cecil county for the first Ultra race of 2020. Right off the trailer it went 4.96, and then a 4.94 Spun a couple passes, but see in the video that it went into tire shake and then spun, so hopefully tire pressure etc can get it consistent again
....BAD A$$ STREET CAR.....
Re: New Best ET
[Re: GY3]
#2782612
06/08/20 05:27 AM
06/08/20 05:27 AM
Posts: 9,871 MI, usa
dvw
MI, usa
Re: New Best ET
[Re: JACK1440]
#2782758
06/08/20 01:07 PM
06/08/20 01:07 PM
n20mstr
Nice.... I heard the track was good this weekend. I'm hoping for the UNSS this weekend. Waiting on the announcement.
What is your combo? 3055LBS 530" BB B1 heads Single Entry nitrous plate 275 radial tire
Re: New Best ET
[Re: n20mstr]
#2782761
06/08/20 01:09 PM
06/08/20 01:09 PM
Posts: 19,382 Las Vegas
Al_Alguire
Las Vegas
Saw the sheet on facebook..Congrats on the new best, sounds like the changes and weight coming out showed a big improvement
Re: New Best ET
[Re: Al_Alguire]
#2782765
06/08/20 01:13 PM
06/08/20 01:13 PM
n20mstr
Saw the sheet on facebook..Congrats on the new best, sounds like the changes and weight coming out showed a big improvement Al, weight is perfect now. Every time I went over the scales it was 3055, im supposed to be 3050. I have the air too low in the tires, and watching the vids I see now that when it spins it shakes the tire first. Its getting really wrinkled up and when the wrinkles hit the bottom of the tire...there it goes, spins . So my plan is add some air, and maybe tighten the ext on the rear shock. There some other things in the progressive that really helped the 60' come around
Re: New Best ET
[Re: n20mstr]
#2782769
06/08/20 01:19 PM
06/08/20 01:19 PM
Al_Alguire
Las Vegas
Its nice to be t minimum for sure, ballast at minimum is even better. You know what they say about shake, just ad more power Sounds like you have a handle on that with air and shock settings but don't forget more power can fix that too .
Re: New Best ET
[Re: n20mstr]
#2782810
06/08/20 02:08 PM
06/08/20 02:08 PM
Posts: 17,907 S.E. Michigan
ZIPPY
S.E. Michigan
Whoa. I can't imagine what that even feels like. Congrats!
Rich H.
Esse Quam Videri
Re: New Best ET
[Re: scottb]
#2783312
06/09/20 04:40 PM
06/09/20 04:40 PM
n20mstr
Nice job Tony you are getting a good handle of your car and it’s flying are you on a slick or a radial slick great job for sure Im on an Ultra Street required Radial. Et Street R 275.
Re: New Best ET
[Re: n20mstr]
#2783636
06/10/20 12:30 PM
06/10/20 12:30 PM
Posts: 12,414 Taxes & Virus's R-US, NY
Dragula
Gezussss, that is flying! I can say, I will probably never go that fast, the learning curve alone to get there is more than enough....Congrats, that is truly flying!
Re: New Best ET
[Re: Mr.Yuck]
#2783662
06/10/20 01:07 PM
06/10/20 01:07 PM
n20mstr
Good job. I'd like to get out to Cecil if I ever get mine junk together. Was Ron out there? Ron ? who are you referring to?
