2011 ram 1500 traction/abs light on in dash and no cruise #2773613
05/11/20 05:35 PM
05/11/20 05:35 PM
S E Michigan
E
ekim Offline OP
ekim  Offline OP
E
S E Michigan
i took it to a shop and the code was for left rear wheel sensor circuit. they tested the sensor and said it was good, but they think there is probably a broken wire someplace. since they would have to charge $$$$ to track it down i said i would live with it.
Is there a common connector to break/corrode on these? it is a 2wd v6 auto if it matters.
Re: 2011 ram 1500 traction/abs light on in dash and no cruise [Re: ekim] #2773945
05/12/20 05:55 PM
05/12/20 05:55 PM
Central NY
GarageDodge Offline
GarageDodge  Offline
Central NY
Check connector where it plugs into sensor,also wires rub through where they are routed on the axle.
Re: 2011 ram 1500 traction/abs light on in dash and no cruise [Re: ekim] #2774053
05/13/20 12:17 AM
05/13/20 12:17 AM
Mentor, OH
doggs330 Offline
doggs330  Offline
Mentor, OH
Doesn't appear to be much to that circuit. I'm having a hard time finding a location for connector C322 and splices S396, S398. Not sure why there would be a splice in the sensor wiring in the first place.
Re: 2011 ram 1500 traction/abs light on in dash and no cruise [Re: doggs330] #2774299
05/13/20 06:35 PM
05/13/20 06:35 PM
S E Michigan
E
ekim Offline OP
ekim  Offline OP
E
S E Michigan
didnt see anything obvious, oh well, i will really miss the cruise.
