Trouble compressing shocks for install?
#2774175
05/13/20 12:31 PM
05/13/20 12:31 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I had to swap the shocks on my 92 D250. The new Bilsteins were too much to compress by hand so I had to get creative. Quick and easy!
Give it a shot next time you have to do that job.
Re: Trouble compressing shocks for install?
[Re: feets]
#2774184
05/13/20 12:49 PM
05/13/20 12:49 PM
Posts: 16,519 On the run…
BloFish
On the run…
Thanks for the tip. I’ll try it when I replace my A100 shocks this week.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: BloFish]
#2774216
05/13/20 02:02 PM
05/13/20 02:02 PM
Posts: 15,926 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Good for rears, but man did I have a rough time with KYB fronts several years back. Coincidentally, I made a remark about it a few days ago on thread asking about KYB's and likes or dislikes.
Thanks for tip.
Facts are stubborn things.
[Re: larrymopar360]
#2774323
05/13/20 07:47 PM
05/13/20 07:47 PM
Posts: 1,410 Central Pa
moparjim79
Central Pa
It Good for rears, but man did I have a rough time with KYB fronts several years back. Coincidentally, I made a remark about it a few days ago on thread asking about KYB's and likes or dislikes.
Thanks for tip. Especially c bodies holy cow!
[Re: moparjim79]
#2774331
05/13/20 08:00 PM
05/13/20 08:00 PM
feets
Senior Management
Senior Management
Irving, TX
Thanks for tip. Especially c bodies holy cow! No kidding. I put some KYB GR2 shocks on the front of the Imperial and really dislike them. They were a huge PITA to get in there and I'm not looking forward to doing that again.
[Re: feets]
#2774761
05/15/20 09:31 AM
05/15/20 09:31 AM
moparjim79
Central Pa
Thanks for tip. Especially c bodies holy cow! No kidding. I put some KYB GR2 shocks on the front of the Imperial and really dislike them. They were a huge PITA to get in there and I'm not looking forward to doing that again. So, building on the ratchet strap idea, I developed a similar shade tree way to install fronts on the c bodies with the "tube"--- I used zip ties and went through the shock eye then over the top stud. Some I had to make up 2 separate zip tie straps( they need to be good zip ties). When the eye is resting in the lower control arm shock slot , after it's been inserted through the tube of the frame, you cut the zip ties and it will release the shock. You just have to guide it into the upper control arm slot. It's a PITA
[Re: Jjs72D]
#2775460
05/17/20 03:18 PM
05/17/20 03:18 PM
feets
Senior Management
Senior Management
Irving, TX
If you don't plan to use these crappy shocks (KYB), Drill a hole in them to remove. That doesn't make it any easier to install the new ones.
[Re: MadMopars]
#2775893
05/18/20 06:18 PM
05/18/20 06:18 PM
Posts: 8,681 Buford, GA
I_bleed_MOPAR
Buford, GA
I put new Gabriels on the front of the Dakota a couple months ago. I couldn't compress and hold them by hand long enough to start the lower bolts. After thinking about it, I got the small portable jack, stood a large 1/2" socket up on it, and jacked it into place. Would also work with the factory scissor jack but be a little more work. Going out in the morning to put in new control arms and springs so I'll probably get to do it all over again. Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
[Re: feets]
#2781973
06/06/20 02:41 AM
06/06/20 02:41 AM
Posts: 2,271 central IL reg Nov 18, 1999
Stroker
I put a pair of Bilsteins on the front of the T&C last year. I was able to compress them, but not long enough to get them positioned to where they'd explode into the right place. I was able to use some butt-kickin' cable ties I had to keep them compressed. Not easy with a bayonet mount on top, lol. After I got one in, I remember thinking that I hoped I'd never have to take them out!
