Temp gauge #277251
04/04/09 09:09 PM
04/04/09 09:09 PM
st. Louis Mo.
dartphil Offline OP
dartphil  Offline OP
st. Louis Mo.
Ok guys, I must be overlooking something. But I cannot see a place on my small block to install an aftermarket tempurature gauge sensor. Any ideas ?? Thanks
Re: Temp gauge [Re: dartphil] #277252
04/04/09 11:25 PM
04/04/09 11:25 PM
Which intake manifold are you using? Are you going to use the heater hoses or block them off How about the thermostat bypass hose and holes? Which type and size sender are you wanting to install in the manifold?
Re: Temp gauge [Re: Cab_Burge] #277253
04/04/09 11:37 PM
04/04/09 11:37 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
Yea im going through the same thing right now, My son got an Edelbrock intake for a magnum motor, its got the spot for a temp sending unit, but its only tapped for 1/8 pipe...?????
Well i got a 1/2" tap and a 23/32 drill bit
....BAD A$$ STREET CAR.....
