Re: 2.28 gear set for 727
[Re: HEMI472]
#2772456
05/08/20 01:32 PM
05/08/20 01:32 PM
Posts: 11,692 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Depends on a lot of variables. Usually more SLR will make the car quicker in 60 to a point, as long as it doesn't spin and the suspension is optimized. Smaller drop at the gear change will help a smallerpeakier engine combo. SLR can be be too much or not enough and make the car a turd. When it's right, it makes the car so much better. Ive gone as quick with a 1.98 as I did with a 2.45, but the suspension was set up differently as well. And it would do that everytime - not hook 3 times and turn the tire the 4th. With a 1.76 it was a turd.
MPH shouldn't be effected unless this is 1/8 mile and the combo is way out of whack.
[Re: dvw]
#2772592
05/08/20 07:26 PM
05/08/20 07:26 PM
Posts: 3,096 Michigan
A727Tflite
One of my customers went to the 2.28 - car was way more manageable off the line and lost a tenth in the quarter.
Making too much lower though - took out the sun gear twice. Had enough - has a glide in it now.
This is an 8.60 car by the way, making north of 1K HP.
[Re: dvw]
#2772593
05/08/20 07:28 PM
05/08/20 07:28 PM
Posts: 4,696 On the parachute mount
n20mstr
honestly its all a matter of trial and error, But here are some things i have learned:
More power needs less SLR More rear gear and less first gear helps converter stay tighter at top, less slippage The more SLR you can hook, the quicker ETs
....BAD A$$ STREET CAR.....
[Re: fbs63]
#2772777
05/09/20 10:20 AM
05/09/20 10:20 AM
Posts: 84 La.USA
rick4106
La.USA
Had a 2.28 first in my sons savoy. 2600 lbs with driver, 4.56,572 single 4, 1.18 60 ft leaving off footbrake at 3000. Broke wheelie bar at 2 day race. Ran Sunday leaving in second gear. Car ran 5.30s leaving in first and 5.50s leaving in second at same mph
[Re: dvw]
#2774190
05/13/20 12:57 PM
05/13/20 12:57 PM
Posts: 292 NY
challenger451ci
NY
Rear gear and the resulting starting line ratio change doesn't affect stuff as bad as you think. My past race car went from a 4.56 to 4.10. Didn't slow it a bit. Just made the same swap with a buddys Eddy headed 10-1 440. 4.56 to 4.10. Didn't slow it down at all. Doug I had similar results going from 4.10 with a 2.45 low gear to 3.73's with 2.28 low gear running NA. Virtually the same ET and 60ft.
