413 RB stroker question #2770768
05/03/20 12:57 PM
05/03/20 12:57 PM
Chattanooga, TN
orange elephants Offline OP
Chattanooga, TN
What’s the largest stroke crank you can put into a 413 without having to modify the block?
Re: 413 RB stroker question [Re: orange elephants] #2770771
05/03/20 01:01 PM
05/03/20 01:01 PM
4.25 stroke with BB Chevy rod journals will fit with a little bit of grinding on the oil pump pick boss to clear the rods, some blocks need it and some don't depending on which rod brand and block castings shruggy
