Re: Are there places in the USA that do Electric Conversions
[Re: 340SIX]
#2767011
04/22/20 08:43 AM
04/22/20 08:43 AM
Posts: 20,673 in a cattle trailer down by th...
Guitar Jones
[Re: Guitar Jones]
#2767121
04/22/20 02:27 PM
04/22/20 02:27 PM
Posts: 2,334 Addison Twp, Mi.
RobG
Addison Twp, Mi.
There were two firm at SEMA last year that were doing conversions. If I was able to go to my office, I would send you the PDF of the brochure. See if SEMA's website has a reference to them.
One firm wanted $80K to convert a car.
I am not rich...but I get off my ass everyday to make sure I am not broke!
Can we get the Mexican cartels to help us with our supply chain issues? They don't seem to have any trouble getting stuff from one place to another.
[Re: AndyF]
#2767164
04/22/20 05:15 PM
04/22/20 05:15 PM
Posts: 3,122 Auburn WA
Dave_J
Auburn WA
At the level our muscle cars need power the costs of a conversion will not be cheap even if you DIY.
The Controller is a hard to set up component. Much more so that just a FI tune. It must be matched to your battery system and the 'MOTOR' voltage. The Battery Maintenance System (BMS) is required to balance the charge of the batteries and the discharge too. Charger's to charge the batteries and work with the BMS. You will need a few chargers depending on how fast you want to recharge. Motors... How big? in a nut shell: Volts=Speed, Amp's=Power (Push) A 48 volt 11Kw/h motor will be slower than a 244 volt 11Kw/h one. Batteries.... Range=A/h, Total Volts=Speed.
Even the best batteries are heavy. I'd bet to power my LRT with enough A/h range and volts it would add 1,000 pounds to the weight in just batteries.
Most aftermarket EV's are minimal shifted gearing. For the city it is around 4.44:1 gear ratio, much more than that and the torque multiplication is wasted. For the freeway a 3:1 ratio will work, much less than that and you are out of the efficiency of the electric motor's power range. So as set of 3.05 Ring and Pinion with a two speed planetary trans that has a 1.45:1 first gear and then a direct drive would work for most. You'd keep it in 1st gear till the motor reached top torque RPM and then shift to drive. No clutches or bands needed.
Retired, US ARMY 1973-1994 ASE mechanic, Electrical 1994-1997 Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter 65 Formula S Cuda 78 Little Red Express Truck 98 Buick Regal (wifes car)
[Re: AndyF]
#2767255
04/22/20 10:26 PM
04/22/20 10:26 PM
Dave_J
Auburn WA
I've seen conversions where they keep a transmission and conversions where they don't. I own a Nissan Leaf and it doesn't have a transmission. Or at least it doesn't seem to have one. I haven't taken it apart to verify anything. There does not appear to be any shifting going on at any speed in the Leaf.
There is a place in Portland OR that I talked to a year ago and they were just starting to produce electric "crate engines" for muscle car conversions. I haven't checked on them lately but when I talked to them they were aiming for 400 hp and 200 mile range. That was the target they thought would allow them to sell a bunch of kits. I think the kit was going to be $50,000 plus whatever the install cost was. Andy, the Leaf does have a transmission but it does not shift. Just a reduction unit. "The Nissan Leaf does not use a typical automatic or manual transmissions. It uses a single speed reduction gear with a final drive ratio of 7.9377. ... Since almost the entire RPM range for the motor produces usable torque, there's no need for a transmission."
