Re: E body 4 speed ??'s
[Re: JohnRR]
#276710
04/06/09 01:13 PM
04/06/09 01:13 PM
Posts: 4,285 Ohio
64dodge572
Ohio
No stock mopar hurst shifters ever used bushings. Are you sure you have an E body shifter? Should have a 7180 on the reverse lever. We do make some bushings that might work for you. Do all the levers have .50" hole in them? Dan
Brewers Performance Inc. 4-speed transmission and parts specialists PH 937-947-4416 or 937-698-4259 FAX 937-947-4419 www.brewersperformance.com
[Re: Krucial_Engineer]
#276712
04/06/09 01:23 PM
04/06/09 01:23 PM
Posts: 75,012 U.S.S.A.
JohnRR
U.S.S.A.
I will check the diameter of the holes in the levers, as well as the #'s on the shifter tonight. It could be a B body shifter. To make a long story short, when I bought the car, it had the shifter mounted in the front location on the trans, and somebody just hacked a hole in the floor, it didn't have the correct floor hump in it, or the e body shifter. It had a B long curved shifter handle on it originally.
No it wouldn't be a B body shifter , no factory shifters used bushings as Wayne stated .
[Re: Snoopy]
#276714
04/06/09 01:27 PM
04/06/09 01:27 PM
JohnRR
U.S.S.A.
You should be able to order a bushing kit from your local speed shop or auto parts store.
Depends on which ends of the rods go in the shifter box ? if it's the adjustable end then yes , but if it's the fixed end then that pin is smaller than the pins on the rods that use bushings ...
No clue here on what rods and levers he has on the trans ???
#276717
04/06/09 05:27 PM
04/06/09 05:27 PM
JohnRR
U.S.S.A.
I have the correct E body shifter rods, and the correct bracekts on the transmission.
The diameter discretion is on the actual hurst shifter mechanism and the non adjustable end of the E body shifter rods. I will measure tonight to verify the diameters. I could turn bushings out of delrin or bronze if needed. I just assumed there were bushings that may work.
I am pretty sure that the adjustable end goes in the shifter box and the fixed end connects to the trans levers , but it still sounds like you have a mix match of original and aftermarket parts .
As far as bushing , use bronze instead of delrin or buy what Brewer makes .
[Re: tecmopar]
#276719
04/07/09 08:38 AM
04/07/09 08:38 AM
JohnRR
U.S.S.A.
Thats right, the adjuster ends go in the shifter for 1-2 and 3-4, on reverse the adjuster goes to the lever on the trans, good luck.
that's what I thought so the OP is assembling it wrong ...
