Hood Pop Up Spring Protector/Cap
#2765526
04/18/20 03:08 PM
04/18/20 03:08 PM
Posts: 1,149 NW New Jersey
RSI700VIPER
NW New Jersey
What do you guys use to prevent scratching the under hood paint on your trailer queen? Is there a rubber cap or cover that fits over the hood spring? I heard people use a 35mm film container lid, but who has those anymore?
1970 Superbird 440 Six BBL, 4-Speed, Dana, FJ5 1969 Daytona Charger 440 4-Speed, Dana, EV2 1971 340 Challenger Conv. Flemington Speedway Pace Car, FC7 1970 340 Six Pack Callenger T/A 4-speed T8 Tan 1971 340 Challenger RT Formal Roof, EV2 w/ V2 Stripe & Orange Houndstooth 1969 Talladega Torino, 428CJ 1969 Gurney Special Cyclone Spoiler II, 351 Cleveland
"Id rather have a bottle in front of me than a frontal lobotomy" Ben Franklin 1755
Re: Hood Pop Up Spring Protector/Cap
[Re: RSI700VIPER]
#2765529
04/18/20 03:25 PM
04/18/20 03:25 PM
Posts: 20,915 A collage of whims
topside
A collage of whims
35mm film lid never worked for me, but a rubber/vinyl cap that's deeper will stay on. Or, you could try that rubber dip stuff. Or, a bit of rubber adhered to the hood underside. All depends on how OEM you want it to look. I also wish I could quit whacking my forehead on the secondary latch hook ! ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif)
[Re: topside]
#2765535
04/18/20 03:38 PM
04/18/20 03:38 PM
Posts: 16,163 Mesa, Arizona
dart4forte
Mesa, Arizona
35mm film lid never worked for me, but a rubber/vinyl cap that's deeper will stay on. Or, you could try that rubber dip stuff. Or, a bit of rubber adhered to the hood underside. All depends on how OEM you want it to look. I also wish I could quit whacking my forehead on the secondary latch hook ! While working on my GTS I keep a tennis ball on the hook. I also keep the tennis ball on the hook when the hood is up at car shows. Several years ago had a lady whack the back of her head while she was looking under the hood. Her husband came up and grabber her around the waste and she jumped and hit the back of her head. She was bleeding all over because she was taking blood thinners. Big mess under the hood. Turned our she went to the ER and they put in 4 stitches. After that the tennis ball went on. On the spring try heat shrink
Abe Lincoln
[Re: jlatessa]
#2765948
04/19/20 01:25 PM
04/19/20 01:25 PM
RSI700VIPER
NW New Jersey
We just threaded an inch of vacuum hose onto the end of the spring.
Simple and it works fine.
Joe Sounds good Joe. I think shrink wrap wouldn't last long and I want to be able to remove it so dipping is out.
[Re: jlatessa]
#2766233
04/20/20 10:25 AM
04/20/20 10:25 AM
Posts: 637 West Central Wi.
1969 HEMI R-T
West Central Wi.
I use a thick rubber vac plug. slip it over the center most end of the spring. and it holds it above the paint for me. I can take a pic.
HEMI,S ARE FOREVER!!!
[Re: DrCharles]
#2766248
04/20/20 11:24 AM
04/20/20 11:24 AM
Posts: 2,924 Calgary, Alberta Canada
a12rag
Is there anything I can put on the hook to prevent it from scratching the radiator support paint when closing? ![work work](/ubbthreads/images/graemlins/custom/work.gif) (Besides a tennis ball) On my 02 Cummins . . . there is a plastic piece about 1/2" wide that came from factory, that mounts to the hole that the "hook" goes through . . . no paint hurt at all !!! . . . as for the "spring" . . .think was already said, but there is one on Ford van hood spring . . . hopefully both are easy to find in the wrecking yards . . . https://parts.moparonlineparts.com/...-engine/body-cat/exterior-trim-hood-scatIt is called "Skid Plate" in diagram above it is #8 - part # 55075178 for the plastic piece that protects the paint from the safety catch hook . . . not sure if it is still available from Mopar anymore . . .
[Re: a12rag]
#2766252
04/20/20 11:35 AM
04/20/20 11:35 AM
Posts: 1,238 Chicago, IL
PLUM_72
Chicago, IL
Check out the pipe caps over at McMaster Carr. These come in Vinyl or hard plastic. The tapered shape of the spring makes things a little strange for a cap. I think you can find something that will work and would be easily removable at a show. https://www.mcmaster.com/pipe-caps/caps-3/round-caps-9/
1972 Dodge Challenger
[Re: PLUM_72]
#2766275
04/20/20 12:06 PM
04/20/20 12:06 PM
RSI700VIPER
NW New Jersey
Check out the pipe caps over at McMaster Carr. These come in Vinyl or hard plastic. The tapered shape of the spring makes things a little strange for a cap. I think you can find something that will work and would be easily removable at a show. https://www.mcmaster.com/pipe-caps/caps-3/round-caps-9/ Plum, If I can't find a vinyl cap to fit my spring from Mcmaster.com, then one does not exist. Thanks for the link.
[Re: Stanton]
#2766654
04/21/20 10:54 AM
04/21/20 10:54 AM
Posts: 4,324 St. Louis, Mo
318 Stroker
St. Louis, Mo
I think its the small Ford vans (whatever they were called) that have a plastic cap on their spring that fit the Mopar springs perfectly. Available at local wrecking yards everywhere. 1994 Ford Windstar. I bought the spring with cap new at the Ford dealer for 10.00. Part # E69Z-16C644-A. It's been some years ago, and the part may now be obsolete. The spring looked the same as my Challenger, so I used it. I have an inside hood release and sometimes the hood wouldn't pop up. I finally figured out that the coil diameter on the Ford spring was thinner, so not enough tension. I went back to my original Mopar spring with the Ford cap, and haven't had a problem since.
[Re: RSI700VIPER]
#2766705
04/21/20 12:47 PM
04/21/20 12:47 PM
Posts: 5,447 So Cal
Sinitro
So Cal
My solution was to use a larger body washer(big washer, small hole) and mount it to the hood, so now the spring hits this rather than a painted surface. Clean no paint dings.. Just my $0.02... ![wink wink](/ubbthreads/images/graemlins/custom/wink.gif)
