Re: A little 572 update with ugly pictures
[Re: DoubleD]
#2764553
04/16/20 10:47 AM
04/16/20 10:47 AM
Posts: 17,860 S.E. Michigan
ZIPPY
S.E. Michigan
How well does the indy valley plate line up against the eddie head? - do you have a pic without the intake? Here you go, D. Being that the intake sits on top of it rather than the heads, it's not going to be as bad to work with as that other style that sits underneath the heads.
Rich H.
Esse Quam Videri
[Re: Cab_Burge]
#2765086
04/17/20 02:34 PM
04/17/20 02:34 PM
ZIPPY
S.E. Michigan
Thanks for the comments. I will (hopefully) find out pretty soon how it works.
The manifold seems it will mostly close the gap (as in the last shot) and the Indy intake is really just for my own education/to get it running and check it out.
I acquired it used and still glued together which gave me a good look at how the previous owner sealed it up. The valley tray got a heavy bead, like 3/8, then the intake was installed on top of that which squished it down, then they went over the bead with the underside with a fingertip or similar. Who knows what heads or other parts they used, though.
It's kind of nice to be able to use the china wall bolts without fear of cracking anything.
Rich H.
Esse Quam Videri
[Re: DoubleD]
#2765592
04/18/20 06:07 PM
04/18/20 06:07 PM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
That spacer dilemma,,,,,been there & done that I like that tunnal ram,been there done that before the blower over 20 years ago!
