Holley Sniper EFI #2757741
03/30/20 08:08 PM
03/30/20 08:08 PM
GeeTeeX Offline OP
GeeTeeX  Offline OP
I have a 1969 GTX with the 440 engine, non air grabber. Does anyone know if the factory round air cleaner base will fit onto the Sniper EFI unit?
Re: Holley Sniper EFI [Re: GeeTeeX] #2757769
03/30/20 08:48 PM
03/30/20 08:48 PM
GeeTeeX Offline OP
GeeTeeX  Offline OP
Ok, does anyone know what size the outside diameter of the Sniper 4150 EFI air cleaner mount is. My stock air cleaner base has a 4 1/8” hole in it.
Re: Holley Sniper EFI [Re: GeeTeeX] #2757790
03/30/20 09:36 PM
03/30/20 09:36 PM
AndyF Offline
AndyF  Offline
Factory air cleaners should fit as long as you use the rear fuel inlets.
