God, i wish I could figure out where all my
coolant goes. The dog is still alive so I can't
be leaking it, no white smoke, no overheating,
and good cyl compression and leakdown test.
borrow one of those stant radiator pressure pumper upper kits & come home with it hot pull the cap & pump it up to 15lbs & check it several minutes later & if it's a real tiny leak you might have to let it sit that way overnight & see how much psi you've lost next morning.
