What mild cam package would you suggest?
#274360
04/01/09 09:11 PM
04/01/09 09:11 PM
Looking to put a cam/lifter package in a stock 440. I am running a 391 gear with an automatic. Want to gain a little more hp but can't afford a total rebuild. Any suggestions?
Re: What mild cam package would you suggest?
[Re: BELVEDERE67]
#274363
04/02/09 12:55 PM
04/02/09 12:55 PM
Lunati Voodoo .454/.475 is good with lower compression. And will work ok with your stock valve springs. If you want more HP go with the .475/.494. You'll need new springs for it though! Both are great street cams And work with MOST of your stock components.IE> carb/intake/valvesprings/converter-etc
#274365
04/02/09 03:24 PM
04/02/09 03:24 PM
It is a 71 440 no mods other than performer intake and eddy carb, electronic ign and plans to go to headers...
[Re: BELVEDERE67]
#274366
04/02/09 03:29 PM
04/02/09 03:29 PM
Thanks! Big fan of your's also....I would like to get some more low end punch. The car is real doggy out of the hole. I changed the rear end ratio last year and it helped but I guess I am looking for more snap in the bottom end.....performer dual plane, eddy carb, electronic ign and thinking of going to headers..
#274367
04/02/09 07:29 PM
04/02/09 07:29 PM
Posts: 731 Aurora Colorado
BELVEDERE67
mopar addict
mopar addict
Aurora Colorado
I'm partial to Comp cams. The xtreme energy h268 look good for your combo. low duration with good lift. Much bigger and your heads will limit effectiveness. I'd get the headers as well. I assume that you want to use stock rocker system. I would replace springs as well. Lots of other ideas out there. This just mine. Good luck.
[Re: BELVEDERE67]
#274368
04/02/09 07:58 PM
04/02/09 07:58 PM
Posts: 2,093 oberlin, Ohio
Rapid340
oberlin, Ohio
I can get you a custom Engle cam. Some for headers others for HP exhaust manifolds. I have a street hydraulic cam that works well with HP manifolds or headers. example: (224,236 .504,.517) with a little wider than std. lobe sep. PM me if interested.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
