Oil leak- HELP! #2743085
02/15/20 07:52 AM
02/15/20 07:52 AM
Sebring, Florida
Mopar Grandpa Offline OP
Sebring, Florida
I have a 2016 Chrysler 300C with the 3.6 engine. I developed on oil leak behind the drivers side rear tire, I assumed it was a leaking shock. I removed the tire and the shock was totally dry. However, I noticed a small diameter rubber hose with a removable cap that ran parallel (vertical) with the rubber gas line, that is the source of the leak. The oil was very clear and heavier than engine oil. I called my local Mopar dealership and spoke with the service manager and a technician, neither of them knew anything about this small diameter rubber hose. I took a picture and sent it to a friend that has worked on newer Mopars for years at a dealership in Indiana and he didn’t know what it is or what it’s connected to. Any help is appreciated.
Re: Oil leak- HELP! [Re: Mopar Grandpa] #2743101
02/15/20 09:15 AM
02/15/20 09:15 AM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
Gramps .... does this hose/line have anything to do with an “ active suspension” ? ... is there a FCA dealer close to you that can give you a no-charge repair quote ?
I’ll tell you this .... I’m not really super impressed with some of these so called service managers that I’ve talked with locally !!
There’s more true and actual hands on knowledge HERE !
Re: Oil leak- HELP! [Re: Mopar Grandpa] #2743107
02/15/20 09:46 AM
02/15/20 09:46 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Any chance its a vent for the rear diff ?
Im not familiar with the new ones. I Left the dealership nearly 10 years ago now ( wow time flies )
Re: Oil leak- HELP! [Re: gtx6970] #2743126
02/15/20 10:34 AM
02/15/20 10:34 AM
CrazyD Offline
CrazyD  Offline
Re: Oil leak- HELP! [Re: gtx6970] #2743149
02/15/20 11:25 AM
02/15/20 11:25 AM
Kirkland, Washington
Pacnorthcuda Offline
I’m thinking this. It definately looks like a vent hose, and the only common vents in that vicinity are the fuel tank and the diff. The diff shouldn’t be dripping more than a drop though....
Re: Oil leak- HELP! [Re: Pacnorthcuda] #2743181
02/15/20 12:54 PM
02/15/20 12:54 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
Most gear oil has a pretty distinctive smell too. Have you gave it a sniff?
Facts are stubborn things.
Re: Oil leak- HELP! [Re: Mopar Grandpa] #2743301
02/15/20 07:44 PM
02/15/20 07:44 PM
N
NITROUSN Offline
NITROUSN  Offline
N
That's the rear axle vent.
Re: Oil leak- HELP! [Re: dOc !] #2743351
02/15/20 09:48 PM
02/15/20 09:48 PM
Sebring, Florida
Sebring, Florida
I’m not sure about an active suspension vent. I don’t think it’s a vent line since it faces down and has a cap. But thanks for your input.
Re: Oil leak- HELP! [Re: larrymopar360] #2743354
02/15/20 09:50 PM
02/15/20 09:50 PM
Sebring, Florida
Sebring, Florida
It doesn’t smell like the old 90 weight rear end lube. It really doesn’t have any smell.
Re: Oil leak- HELP! [Re: NITROUSN] #2743356
02/15/20 09:53 PM
02/15/20 09:53 PM
Sebring, Florida
Sebring, Florida
I located the differential vent on top of the housing, just a very short section of hose with a plastic vent. I couldn’t feel any other hoses in the area. Since I don’t have a lift it’s hard to see everything under the vehicle. Thanks for your input.
Re: Oil leak- HELP! [Re: Mopar Grandpa] #2743381
02/15/20 11:02 PM
02/15/20 11:02 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Is this line in your picture located right next to the fuel tank filler tube?
Re: Oil leak- HELP! [Re: NITROUSN] #2743387
02/15/20 11:20 PM
02/15/20 11:20 PM
I know the OP said “heavier than engine oil” but could that be the drain hose for the fuel filler cap area?
Re: Oil leak- HELP! [Re: Pacnorthcuda] #2743389
02/15/20 11:21 PM
02/15/20 11:21 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
He said it didn't smell like gear oil, I imigine if it smelled like gas he'd notice that?
Re: Oil leak- HELP! [Re: Sniper] #2743391
02/15/20 11:29 PM
02/15/20 11:29 PM
If you are responding to my post, be aware the drain surrounding the fuel cap also drains water....from rain and car wash etc.
Re: Oil leak- HELP! [Re: Pacnorthcuda] #2743399
02/16/20 12:07 AM
02/16/20 12:07 AM
Conroe , Texas
I
iapco103 Offline
iapco103  Offline
I
Conroe , Texas
Is this car a convertible? Paul
Re: Oil leak- HELP! [Re: NITROUSN] #2743439
02/16/20 08:21 AM
02/16/20 08:21 AM
Sebring, Florida
Sebring, Florida
Yes, line runs next to filler tube.
Re: Oil leak- HELP! [Re: iapco103] #2743440
02/16/20 08:26 AM
02/16/20 08:26 AM
Sebring, Florida
Sebring, Florida
Chrysler 300 doesn’t have any convertibles.
Re: Oil leak- HELP! [Re: Pacnorthcuda] #2743442
02/16/20 08:35 AM
02/16/20 08:35 AM
Sebring, Florida
Sebring, Florida
I put some gas in a squeeze bottle and poured/squeezed it in the overflow hole to see if it drained thru this hose, it didn’t. Remember, this hose has a removable cap but isn’t shown in the picture. Can’t figure why the Chrysler engineers designed a capped drain hose if it isn’t intended to drain anything. BTW, the cap was split which allowed this fluid to drain. I’m guessing there was about 8 ounces on my floor.
Re: Oil leak- HELP! [Re: Mopar Grandpa] #2743500
02/16/20 11:06 AM
02/16/20 11:06 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Can't answer why there is oil. Behind the plastic fender liner I believe there are fuel vapor containment components for emissions. It could be a service port for test equipment hence the cap.. Just a guess. I also thought of what has been mentioned about a filler neck water drain. Looks like a trip to a dealer to see if they can advise once seen. Has the car ever been worked on or wrecked in that area?
Re: Oil leak- HELP! [Re: NITROUSN] #2743607
02/16/20 03:17 PM
02/16/20 03:17 PM
Sebring, Florida
Sebring, Florida
No, we bought the car new. Never wrecked or serviced by anyone other than one dealer oil change since new. I do everything myself. I’ll probably take the picture to the dealership to avoid a charge for a diagnosis.
[/align][align:left]
