Re: Enclosed trailer advice?
[Re: justinp61]
#2879136
01/23/21 07:36 PM
01/23/21 07:36 PM
Posts: 43,541 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
As others have mentioned, use at least a 5200# axles with brakes on both axles. Over the years I've seen enclosed trailers with 3500# axles that have the tires tilted in at the top. It doesn't cost much more to upgrade to the right axle. IMHO on any 24' trailer it should be mandatory to run at least a 5200# axle. My 18' open goose neck car hauler has 5200# axles under it.
Buy good tires. I tow with a open trailer and last summer installed 15" Goodyear Endurance, load range E radials. It tows nice and smooth, money well spent. What? Goodyear finally makes a good trailer tire? If you put truck or car tires on a trailer in Illinoise you WILL get pulled over and fined bigly...
JB Rhinehart, Realist
A-Body's RULE!
[Re: Rhinodart]
#2879175
01/23/21 09:57 PM
01/23/21 09:57 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
Buy good tires. I tow with a open trailer and last summer installed 15" Goodyear Endurance, load range E radials. It tows nice and smooth, money well spent. What? Goodyear finally makes a good trailer tire? If you put truck or car tires on a trailer in Illinoise you WILL get pulled over and fined bigly... It's a trailer tire. I don't live in a communist state, thank God.
[Re: justinp61]
#2879186
01/23/21 10:36 PM
01/23/21 10:36 PM
Posts: 22,696 Bitopia
jcc
Bitopia
I guess the real topic here is transporting a race car. That being said, last week I stopped off at a used school bus lot. Not sure I'm maybe fond over the finished look, and one would need some fabrication skills, but with a diesel real truck air ride chassis, converting it to an RV, and an enclosed car hauler, with always the possibility of hauling a second race car. or an errand vehicle, I liked all the options. School buses appear to be become obsolete (seat belts, crash protection, etc), rather than worn out, are seldom if ever overloaded, likely are run empty 50% of their mileage, are well maintained, never driven hard, are rather plentiful, and come in all sizes. Biggest downside, to me they are seldom high or over powered.
[Re: jcc]
#2879360
01/24/21 01:35 PM
01/24/21 01:35 PM
Posts: 19,396 north of coder
moparx
i always liked the idea of using a school bus as a vehicle hauler. around here, the prices i have seen seem cheap to me for a pretty nice, somewhat low mileage starting point. as i have had the "privilege"[ ] to drive trucks with auxiliary transmissions, the ones where you loop your arm through the steering wheel to shift gears, the "low or under powered" statement might be a moot point with a two speed rear axle. however, most buses now days are equipped with automatic transmissions, and i don't know if a guy could retrofit a two speed rear axle to one of those or not.
[Re: moparx]
#2879651
01/24/21 10:20 PM
01/24/21 10:20 PM
justinp61
W. Kentucky
i always liked the idea of using a school bus as a vehicle hauler. around here, the prices i have seen seem cheap to me for a pretty nice, somewhat low mileage starting point. as i have had the "privilege"[ ] to drive trucks with auxiliary transmissions, the ones where you loop your arm through the steering wheel to shift gears, the "low or under powered" statement might be a moot point with a two speed rear axle. however, most buses now days are equipped with automatic transmissions, and i don't know if a guy could retrofit a two speed rear axle to one of those or not. Mack B-61 Thermodyne with a Triplex? A buddy of mine had one he pulled a low boy with, it was always fun watching him double clutch with one arm through the wheel and a shifter in each hand.
