Re: Compression question
[Re: Harley]
#2740856
02/08/20 03:01 AM
02/08/20 03:01 AM
Posts: 43,263 Bend,OR USA
Cab_Burge
What quality, octane rating, gas are you wanting to run and if it is ethanol how much % is in it?
[Re: Harley]
#2740899
02/08/20 09:53 AM
02/08/20 09:53 AM
Posts: 4,210 New York
polyspheric
New York
increase the thickness of the head gaskets to lower compression Don't.
Boffin Emeritus
[Re: Harley]
#2740904
02/08/20 10:14 AM
02/08/20 10:14 AM
Posts: 881 Missouri
jwb123
Missouri
Static compression ratio is simply a static measurement of the volumes of the cylinder at top and bottom dead center, and is only one factor in running an engine on low octane fuel. How much cylinder pressure actually happens in the cylinder and the cam timing events are much more important. For example I built several engines for some truck pullers several years ago, who had as a class rule pump gas only, I used 14 to 1 dome pistons in those engines, they worked very well. A good engine program will tell you much more about if your combination will work. Their are several, I use performance trends, it will calculate if detonation will be a problem and calculate a timing curve to allow you to make the engine live. When I do a pump gas build, I plug the numbers into the program, get the timing curve, and then set the distributor up in a distributor machine to match, it is in the ball park every time I have done it. I have even used this method to set up initial timing maps for boosted applications with electronic fuel injection. The program allows you to enter the octane fuel and the amount of boost, and it will tell you how much you need to retard the timing through the curve. And with the cost of engine parts and machine work, around $100.00 is a small price to pay, plus it's fun to waste time with on rainy days as well. And with any computer program is garbage in garbage out, you have to take the time to accurately enter the parameters of your engine, wild guesses will not get it. I use Pipemax as well, especially in building headers and picking intake manifolds.
[Re: Harley]
#2740914
02/08/20 11:07 AM
02/08/20 11:07 AM
Posts: 12,226 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
On my 440 based street/strip 500" engine, I ran right at 11:1 for years on pump gas with no problems. That was with good quench. Your cam and converter will help you. As already covered, don't sacrifice quench in order to lower the CR.
P.S. That was with aluminum heads.
Master, again and still
[Re: Harley]
#2740939
02/08/20 01:08 PM
02/08/20 01:08 PM
Posts: 1,763 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
SB Mopar (360), hydraulic flat tappet cam (Hughes Engines HE3844AL cam, .535/.540 lift, 237/243 dur. @ .050", 286/290 adv. dur., 108 LSA.), 10.7:1 static CR, open chamber factory '596 head castings, heavily ported, chambers polished up and literally no quench volume to speak off (meaning it's absolutely dismal by all accounts, I have about 0.090" between piston top and chamber floor).
Previously was at 9.7, did a head re-surface to get to 10.7, my cranking compression went from 165 to 185-190 psi.
I run 91 octane pump-gas now, was previously running 94 but went lower to try this out, aggressive ignition curve (21 @idle, 35 in by 2000RPM).
Rest of drivetrain probably gives me some room (and is forgiving), this is a street car (3600 lbs), but 4K converter and 4.10 gear, so off-idle and part-throttle the motor has some chance to rev up easily and not quite feel the load that may lead to detonation at lower RPM...at least that's how I interpret my results so far (may be off on this...).
[Re: Harley]
#2740955
02/08/20 02:09 PM
02/08/20 02:09 PM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
Maybe it's time for a fresh set of aluminum heads?
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: Harley]
#2741076
02/08/20 09:32 PM
02/08/20 09:32 PM
Posts: 14,513 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
When it absolutely positively has to run on pump gas....... along with the fact that it’ll probably never go to the drag strip again........ is it really worth pushing the CR envelope?
How much power do you really think you’re leaving on the table if the compression is 10:1 instead of 10.5:1?
And then there’s the question of 93 octane pump gas. It’s not available everywhere. Who’s to say how long it will remain available in your area?
I’d shoot for about 10:1, and put in a cam that makes more sense with how you’re using that car.
For a 505, something like an Icon 842 piston set up at zero deck, along with a set of 75-78cc heads puts you right in the sweet spot.
[Re: Harley]
#2741147
02/09/20 10:18 AM
02/09/20 10:18 AM
Posts: 16,929 NC
440Jim
NC
What is a safe compression ratio to run with pump gas? There are a bunch of variables, and the wide range of responses shows that. Here is what I will add. 1) If you need to put close to $1000 to fix the guides, valve job, resurface, replace parts, etc. Then just buy aluminum heads. You will tolerate more CR & make more power. 2) Your combo has several things that should help tolerate CR, but still your experience shows your current CR is too much. The timing curve change can help, but may not be the only thing needed. If you could reliably control the timing curve to come in much later (3000 rpm?) it stands a better chance. 3) That 68cc chamber is a problem. 10.0 CR should work with 93 octane, and no need to push it over 10.5 with iron heads. IMO
[Re: Harley]
#2741417
02/09/20 10:29 PM
02/09/20 10:29 PM
Cab_Burge
I agree with you Jim my current heads need to much money to repair. i just have to pull the trigger and order a set of heads which i should have done years a go, Buy the best you can afford, not the cheapest ones get the big ones
[Re: Harley]
#2741522
02/10/20 11:29 AM
02/10/20 11:29 AM
polyspheric
New York
One reason aluminum heads are less knock sensitive: less power.
Boffin Emeritus
[Re: DaveRS23]
#2741527
02/10/20 11:51 AM
02/10/20 11:51 AM
Posts: 10,013 Frostbitefalls MN (Rocky&Bullw...
gregsdart
EDIT; I agree on contacting Todd Marsh. He may be able to add a bit of chamber volume as well if required to get the right combo.
