Radiator size #2733717
01/16/20 07:15 PM
01/16/20 07:15 PM
ma.
roadrunner34 Offline OP
ma.
I'll be changing my combination na on gas to procharged on alcohol. This means I can downsize my cooling system. How small of a radiator do you think I can get away with? I do drive the car back to the pits and it would also be nice to free up some space up front to fit the fuel cell.
Re: Radiator size [Re: roadrunner34] #2733729
01/16/20 08:05 PM
01/16/20 08:05 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I take it you don't have a crank mount Procharger.
Re: Radiator size [Re: Clanton] #2733780
01/16/20 11:33 PM
01/16/20 11:33 PM
PA
moparacer Offline
moparacer  Offline
PA
I run my car on alky with a 1 Row aluminum Dodge caravan radiator lol. Its a big block that is tall filled to water pump holes. The 84-89 caravan rad is narrow and sets right beside the 3 gallon fuel cell on the right hand side of the factory core support. I actually only had to drill a couple of holes up top to make it work.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Radiator size [Re: Clanton] #2733805
01/17/20 07:04 AM
01/17/20 07:04 AM
ma.
ma.
No, side slinger.
