2.19 intake valves for Eddy RPM heads
#2731640
01/10/20 06:03 AM
01/10/20 06:03 AM
Posts: 214 Hamburg / Germany
Den300
Hamburg / Germany
Hello, does anybody knows where to get 2.19" intake valves for Edelbrock RPM heads (part nr. 60929)? 11/32" (0.341") steam diameter and 4.908" length. Seems that Hughes Engines are the only ones or I am to blind? Dan Dvorak seems to be out of business and Manley & Co dont list them in there catalogue. Any other vendors?
And do I Need new seat or can I use the ones that come with the 2.14" valves?
thanks! Dennis
Hamburg/Germany
69 Chrysler 300 446cui Dual Quad 12.64 @ 110.7
Re: 2.19 intake valves for Eddy RPM heads
[Re: Den300]
#2731715
01/10/20 12:05 PM
01/10/20 12:05 PM
Thumperdart
State of confusion
I had Pettis install 2.19 valves in my rpm's and I'd say an easy 6.15 @ 112 mph on a crappy 1.40 60 ain't so bad and I think they are REV or something like that iirc........
[Re: Jerry]
#2731754
01/10/20 01:41 PM
01/10/20 01:41 PM
Den300
Hamburg / Germany
is it worth spending the money to upgrade the edelbrock heads with larger valves? can the port support the larger valve? is money better spent getting a better head? maybe a trickflow240 or 270.. asking the questions because I don't know.
Absolute, but I do run old school domed TRWs and I am afraid this wont match with the much smaller and different shaped combustion chamber. And changing pistons leads to rebalancing, etc..thats out of scope timing wise, but the TF are for sure great valued heads! Might use them for next year with a 512 Stroker as I got a brand new 337 intake to play with
Hamburg/Germany
[Re: Den300]
#2731768
01/10/20 02:04 PM
01/10/20 02:04 PM
Posts: 4,700 Wichita
GY3
Wichita
thanks! Dennis I saw on Facebook yesterday where Dan Dvorak is in the hospital with cancer and not doing well.
[Re: GY3]
#2732050
01/11/20 05:53 AM
01/11/20 05:53 AM
Den300
Hamburg / Germany
thats sad! this f... disease...he was alsways very kind on the phone
Hamburg/Germany
[Re: Jerry]
#2732052
01/11/20 05:57 AM
01/11/20 05:57 AM
Den300
Hamburg / Germany
I don't; know if anyone has flowed a set of the rpm heads after cnc porting and with 2.19 valves. I assume your heads still have the stock intake port and not the max wedge ports. I run a set of edelbrock heads from when the first came out and were the only game in town. it would be good to know if you gain anything by going to the larger valves. Based on my readings some 10-20+ cfm in the mid range. We dont have a flow bench so no real chance to measure it precise. Heads are already hand ported and roughly 20% larger then stock but not max wedge. It would shift max hp too high as the car is used 75% on the street. 15 years ago Indy was overkill and RPMs the only real alternative.
Hamburg/Germany
[Re: krautrock]
#2732122
01/11/20 12:45 PM
01/11/20 12:45 PM
Posts: 2,872 Pattison Texas
CSK
Pattison Texas
i don't have time to look, but i think i remember there being some 2.19 intake valves for the RPM heads here. http://www.sivalves.com/ Yes thy do have them , sure wish I would have seen these when I redid my Stealths 2 years ago. Thank You for the link !!!
[Re: Den300]
#2732126
01/11/20 12:49 PM
01/11/20 12:49 PM
Posts: 4,457 Washington
madscientist
Washington
Been there before but they are all a bit too long. Will talk to my engine builder if that still fits with the springs and retainers. But thanks for suggestion So what if they are a bit too long? By how much? .060? .100? If so, you can use a different spring for the longer installed height and get the spring load back where it should be (if it's .060 or so I'd shim the spring you have). Then, you go to b3racingengines.com and read ALL his tech pages. Then order a geometry correction kit and you are DONE. If you do that, and you can use a bit longer valve out of a catalog, you'll most likely never get screwed again by not being able to by a valve off the shelf.
