Re: building a billet motor plate
[Re: jcc]
#2732790
01/13/20 07:56 PM
01/13/20 07:56 PM
Posts: 656 Florida
CJD AUTOMOTIVE
Its beautiful, but with that investment, I feel like it would be hard to ever in the future change my mind. I have a decent investment in small block stuff. I am hopeful with the latest Ritter block, so don't ever anticipate a change. This old dinosaur will do everything I need it to, and not running a Gen 3 Hemi actually makes it unique. Now if an iron race tall deck Gen 3 block ever became available... You might also consider adding a 3/4 axis CNC to your shop. That may be coming once I enclose and air condition the other side of the shop...some day. Did you mention the alloy? 6061-T6 for everything except the tensioner assembly and idler pulley standoffs. Those are steel.
Craig Scholl CJD Automotive, LLC Jacksonville, FL www.CJDAUTOMOTIVE.com904-400-1802 "I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
[Re: hemi-itis]
#2800159
07/23/20 11:14 AM
07/23/20 11:14 AM
Posts: 656 Florida
CJD AUTOMOTIVE
[Re: RATTRAP]
#2800170
07/23/20 11:25 AM
07/23/20 11:25 AM
Posts: 656 Florida
CJD AUTOMOTIVE
Nice machine work, What machine shop did you send it too?
Thanks, Michigan Machine Worx in Lapeer
[Re: MR_P_BODY]
#2800172
07/23/20 11:28 AM
07/23/20 11:28 AM
Posts: 656 Florida
CJD AUTOMOTIVE
I can see why that part is so pricey.. that started as a THICK piece... very nice Thanks, Yep, 1-1/2" thick. Needed that much to be able to enclose the timing belt. It's pocket milled front and back. SW shows about 20 lbs. I'm good with that for an accessory drive bracket/motor mounts/and water pump back plate/timing belt cover.
[Re: CJD AUTOMOTIVE]
#2800234
07/23/20 02:09 PM
07/23/20 02:09 PM
Posts: 17,892 S.E. Michigan
ZIPPY
S.E. Michigan
Well, there's something we've never seen on ebay!
Amazing stuff.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2800309
07/23/20 04:45 PM
07/23/20 04:45 PM
Posts: 4,278 Morrow, OH
markz528
Morrow, OH
I'm crazy enough to make something like that. There are a couple tricky parts there for me to machine, but my machine is capable of machining that.....
[Re: markz528]
#2800310
07/23/20 04:53 PM
07/23/20 04:53 PM
Posts: 656 Florida
CJD AUTOMOTIVE
I'm crazy enough to make something like that. There are a couple tricky parts there for me to machine, but my machine is capable of machining that..... I was shocked that shops simply said, "nope, not interested". I provided the SW native files so tool paths would be easy to do. Just need a big Z axis for the water pump back plate...or a 5 axis/horizontal bore.
#2800324
07/23/20 05:45 PM
07/23/20 05:45 PM
Posts: 1,581 N/E, Michigan
RATTRAP
N/E, Michigan
I'm crazy enough to make something like that. There are a couple tricky parts there for me to machine, but my machine is capable of machining that..... I was shocked that shops simply said, "nope, not interested". I provided the SW native files so tool paths would be easy to do. Just need a big Z axis for the water pump back plate...or a 5 axis/horizontal bore. I see no 5 axis machining requirement for that part, Am I missing something??
[Re: RATTRAP]
#2800333
07/23/20 06:00 PM
07/23/20 06:00 PM
Posts: 656 Florida
CJD AUTOMOTIVE
You are correct. Tall Z axis or horizontal bore.
#2800335
07/23/20 06:05 PM
07/23/20 06:05 PM
markz528
Morrow, OH
I'm crazy enough to make something like that. There are a couple tricky parts there for me to machine, but my machine is capable of machining that..... I was shocked that shops simply said, "nope, not interested". I provided the SW native files so tool paths would be easy to do. Just need a big Z axis for the water pump back plate...or a 5 axis/horizontal bore. My mill is a bed mill so I think it would of fit fine. I don't do it for a living - just to play. I can understand why the pros would not have interest. Not anywhere on your scale - which is very impressive, but this is an adapter I made to fit regular 440 M/T Valve Covers on a B1 head. It was a real pain to engineer, but came out real good.
[Re: markz528]
#2800373
07/23/20 07:55 PM
07/23/20 07:55 PM
Posts: 6,147 Melbourne , Australia
LA360
Impressive work Craig, an admirable piece of work. I only wish I had the time for constrcting something like that.
Alan Jones
[Re: LA360]
#2800532
07/24/20 09:40 AM
07/24/20 09:40 AM
Posts: 22,696 Bitopia
jcc
Bitopia
VEry niCE Was it ever pondered to do a machineable wax mockup as a trial first? I would have a little tense until its it in place and installed.
[Re: jcc]
#2800607
07/24/20 12:30 PM
07/24/20 12:30 PM
Posts: 656 Florida
CJD AUTOMOTIVE
[Re: jcc]
#2800610
07/24/20 12:38 PM
07/24/20 12:38 PM
Posts: 656 Florida
CJD AUTOMOTIVE
VEry niCE Was it ever pondered to do a machineable wax mockup as a trial first? I would have a little tense until its it in place and installed. You mean like 3D printing the parts and CNC routering a wood template?......
[Re: HemiDart68]
#2800630
07/24/20 01:17 PM
07/24/20 01:17 PM
Posts: 656 Florida
CJD AUTOMOTIVE
