Dyno LB/H fuel
#2730254
01/05/20 01:13 PM
01/05/20 01:13 PM
Posts: 2,861 Pattison Texas
CSK
Pattison Texas
How does a Super Flow 901 dyno get the LB /H fuel consumption, is it just a calculation from the AFR & the CFM flow meter, or does it have a actual fuel flow meter ? Thanks, Charlie
Re: Dyno LB/H fuel
[Re: CSK]
#2730260
01/05/20 01:27 PM
01/05/20 01:27 PM
Posts: 14,499 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
A Flow meter determines volume. An entered specific gravity figure and a fuel temp measurement allows for a volume/weight calculation in the software.
Fuel flow is displayed in lbs/hr(I’ve never looked, but you can probably display it another way if using WinDyn software)...... bsfc is calculated from observed uncorrected hp and measured fuel flow.
Re: Dyno LB/H fuel
[Re: CSK]
#2730266
01/05/20 01:50 PM
01/05/20 01:50 PM
Posts: 31,042 Oregon
AndyF
There should be a fuel flow turbine on the dyno. You can double check the flow turbine calibration with a gas can, a scale and a stop watch.
The flow turbine might not get used on EFI engines since it might be capable of handling high pressure. Most EFI systems have a built in flow meter so it doesn't matter. EFI systems have a lot of built in sensors which makes it much easier on the dyno.
Re: Dyno LB/H fuel
[Re: fast68plymouth]
#2730267
01/05/20 01:51 PM
01/05/20 01:51 PM
CSK
Pattison Texas
Thanks Dwayne & Andy, a friend of mine has a race car I am helping him with, the CORRECTED #'s are very high, using the BSFC & LB/H fuel to get the uncorrected HP is much closer to the times that the car runs at the track, he is VERY disappointed, its a 500 cid Pontiac in a 78 Z28.
Re: Dyno LB/H fuel
[Re: CSK]
#2730275
01/05/20 02:04 PM
01/05/20 02:04 PM
fast68plymouth
So. Burlington, Vt.
Pretty simple really.......
You don’t race in corrected air....... and they don’t hand out corrected time slips.
If you tested on a day when there’s 10%+ correction...... that’s 10%+ you don’t have at the track.
If you had 500hp uncorrected on the dyno, and similar air at the track....... you’ll get 500hp performance....... and often...... minus whatever losses you incurred by having the motor in the car vs the dyno(drivetrain parasitic losses, under hood air, mufflers, crank driven cooling fan, etc).
If the dyno correction factors are high(which I’m sure they often are in Texas)...... those corrected numbers are just “pie in the sky”....... unless you can find some “standard day” air(60*, 29.92” baro, zero humidity) to race in.
I like to use 10% for a typical bracket car........ as a starting point.
Take the corrected power, knock 10% off...... plug that into the Moroso chart.
If the dyno correction is over 10%, I’d probably use something like 5% more than whatever the correction was, and plug that into the Moroso chart.
FWIW, I feel like the most productive way to try and tune on the dyno is to do it in similar weather to what you race in.
Re: Dyno LB/H fuel
[Re: AndyF]
#2730278
01/05/20 02:07 PM
01/05/20 02:07 PM
CSK
Pattison Texas
They used STP correction instead of SAE
Re: Dyno LB/H fuel
[Re: CSK]
#2730282
01/05/20 02:19 PM
01/05/20 02:19 PM
fast68plymouth
So. Burlington, Vt.
633.5hp@6000...... so......damn close to 10% correction.
Plus that pull is done with water temps that are going to be pretty hard to duplicate at the track. And, depending on the combo and the tune...... that could easily be another 10-20hp you wouldn’t have in the car.
The pulls, and tuning should be done at the actual operating water temps.
I can see where the ET’s would coincide with numbers closer to 580-600hp.
Dang........ that air temp is pretty unfriendly.
Re: Dyno LB/H fuel
[Re: CSK]
#2730286
01/05/20 02:27 PM
01/05/20 02:27 PM
Posts: 43,204 Bend,OR USA
Cab_Burge
Your friend may need to work on the chassis and drivetrain to make the car faster with the motor the way it is, what do the time slips and spark plugs look like? On the BSFC it looks a little rich, especially above 5000 RPM, maybe try leaning it down a smidge to see if the MPH picks up or not If it does and the 60 ft. get worst then traction maybe limiting the cars times Torque converters in a race car can really hold the car back, compare his time slips to other similar cars at the track during the same time frame to see if that will help or not I've also seen fuel delivery systems limit cars that the owners didn't thank it was, can you fatten the jetting up enough to slow the 1/4 MPH down? If not fix that next How heavy is the car and what is it running ET and MPH on what length tracks?
Re: Dyno LB/H fuel
[Re: CSK]
#2730287
01/05/20 02:28 PM
01/05/20 02:28 PM
AndyF
Air temp of 102 is hot. Was it really that hot that day or did they move the sensor over close to the headers? That is why the correction factor is so high.
And I'd like to know how the water temp was only 110 when the air temp was 102? That doesn't really make sense.
Re: Dyno LB/H fuel
[Re: AndyF]
#2730288
01/05/20 02:28 PM
01/05/20 02:28 PM
CSK
Pattison Texas
His now race car is no faster than his 525 hp street car 1978 Trans Am, he was thinking a low 10 car, in good air its been 10.8 @ 124, 3600 lb race weight , when we rent the track again we will do some tuning, we put a looser converter in it, will also work on my Charger when we go.
Re: Dyno LB/H fuel
[Re: AndyF]
#2730289
01/05/20 02:29 PM
01/05/20 02:29 PM
CSK
Pattison Texas
Air temp of 102 is hot. Was it really that hot that day or did they move the sensor over close to the headers? That is why the correction factor is so high. Yes that is a typical summer day here in Southeast Texas
Re: Dyno LB/H fuel
[Re: CSK]
#2730290
01/05/20 02:31 PM
01/05/20 02:31 PM
AndyF
His now race car is no faster than his 525 hp street car 1978 Trans Am, he was thinking a low 10 car, in good air its been 10.8 @ 124, 3600 lb race weight , when we rent the track again we will do some tuning, we put a looser converter in it, will also work on my Charger when we go. Car performance and dyno power are two totally different things. Some cars can put the power to the ground but most can't. You have to figure out what problem you are trying to solve.
Re: Dyno LB/H fuel
[Re: AndyF]
#2730291
01/05/20 02:32 PM
01/05/20 02:32 PM
fast68plymouth
So. Burlington, Vt.
I’ll often do a low water temp pull at the end of the session for the “hero pull”.
Here’s an example of what I see as fairly typical....... Corrected power- 652hp Uncorrected power- 632hp Moroso chart power based on actual weight/mph at track- 605hp
I have a few customers who have the numbers closer than that....... but frankly, most are worse.
Re: Dyno LB/H fuel
[Re: CSK]
#2730292
01/05/20 02:34 PM
01/05/20 02:34 PM
AndyF
Air temp of 102 is hot. Was it really that hot that day or did they move the sensor over close to the headers? That is why the correction factor is so high. Yes that is a typical summer day here in Southeast Texas Okay, if the air temp was 102 then a 10% correction factor is very realistic, maybe even low. But the water temp of 110 degrees doesn't make any sense. There is zero chance that a bracket car cooling system will operate at 110 degrees when the air temp is 102. He will be lucky to run that engine at anything less than 180 degrees when it is that hot outside. Either the temp gauge on the dyno was broken or the dyno operator was trying to fudge the numbers. I don't know which but it doesn't make any sense. 80 degrees of engine temp can make a big difference. How hot does the engine run at the track?
Re: Dyno LB/H fuel
#2730297
01/05/20 02:40 PM
01/05/20 02:40 PM
CSK
Pattison Texas
I have a few customers who have the numbers closer than that....... but frankly, most are worse. That does seem correct, it has a full 3 1/2 exhaust, air filter, clutch fan, it was dead hooking, 1.75 60ft, we did a converter change, installed electric fans, our track will open back up at the end of this month, he said to me WTH your heavy a$$ street car Charger MPH is about the same as this car.
Re: Dyno LB/H fuel
[Re: AndyF]
#2730298
01/05/20 02:42 PM
01/05/20 02:42 PM
CSK
Pattison Texas
Air temp of 102 is hot. Was it really that hot that day or did they move the sensor over close to the headers? That is why the correction factor is so high. Yes that is a typical summer day here in Southeast Texas Okay, if the air temp was 102 then a 10% correction factor is very realistic, maybe even low. But the water temp of 110 degrees doesn't make any sense. There is zero chance that a bracket car cooling system will operate at 110 degrees when the air temp is 102. He will be lucky to run that engine at anything less than 180 degrees when it is that hot outside. Either the temp gauge on the dyno was broken or the dyno operator was trying to fudge the numbers. I don't know which but it doesn't make any sense. 80 degrees of engine temp can make a big difference. How hot does the engine run at the track? 185-195
