Challenger Dana Stud Challenge
#272674
03/31/09 05:52 PM
03/31/09 05:52 PM
I have a Dana rear-end purchased at the Nat's many years ago. Now putting on car and discovered two of the left axle stud holes are a little wallowed out. Previous owner had changed to RH thread. I want to go back LH thread.
The challenge is to find oversize studs (knurls and thread and have cut down and LH threaded); fix the two axle holes (machine shop?), or replace axle.
Anyone run into this or know where I might find oversize knurl LH studs, or oversize knurl RH I can have machined downed and LH threaded?
Thanks!
Re: Challenger Dana Stud Challenge
[Re: DoctorDiff]
#272676
03/31/09 08:35 PM
03/31/09 08:35 PM
Not sure I want to trust the tack weld, but the plug weld and redrill may be the answer!
