"updated" on reverse manual valve body trans!
#271809
03/30/09 06:29 PM
03/30/09 06:29 PM
Posts: 926 MICHIGAN
BB65Barracuda
MICHIGAN
I have just purchased a cheetah reverse manual valve body for my 727 and have the stock floor shifter and center counsel in my 68 Barracuda. Anyone use this setup or do I have to do aftermarket?
1957 Power wagon wm300 original 10.000 mile truck, 1964 dodge Polara Convertible numbers matching
Re: Need shifter info on reverse manual valve body trans!
[Re: AARCONV]
#271815
04/05/09 10:32 AM
04/05/09 10:32 AM
Posts: 926 MICHIGAN
BB65Barracuda
MICHIGAN
Installed and works great!! Big Differance with 3800 convertor and manual valve body. Thanks for the help.
Re: info on reverse manual valve body trans! Updated
[Re: BB65Barracuda]
#271816
04/05/09 04:47 PM
04/05/09 04:47 PM
Posts: 926 MICHIGAN
BB65Barracuda
MICHIGAN
Uh oh I seem to be havein 2nd gear burnout problems!! The car launches awesome in 1st and boils the tires all the way into 2nd gear and up shifts and down shifts fine but the car does not want to do a 2nd gear burnout as detailed in the paperwork. The trans has all the goodies installed bolted sprag, good clutches etc.. did I brake it already? Besides the 2nd gear burnout thing it seems mint. Band adjustment perhaps.I really dont want to remove it if I dont have to.
[Re: BB65Barracuda]
#271817
04/05/09 04:55 PM
04/05/09 04:55 PM
Posts: 101 Oregon
RoadRaceDart
For the burnout. Are you backing into the water or rolling through it?
Joshua
[Re: RoadRaceDart]
#271818
04/05/09 06:27 PM
04/05/09 06:27 PM
Posts: 926 MICHIGAN
BB65Barracuda
MICHIGAN
Currently not able to hit the track, I'm in the Detroit area and we are suppose to get snow tonight ARGH! But up until today the weather has been decent enough to get the car out and tested. Why do you ask?
[Re: BB65Barracuda]
#271819
04/05/09 06:48 PM
04/05/09 06:48 PM
Posts: 30,424 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
The car launches awesome in 1st and boils the tires all the way into 2nd gear .......
I would TRY doing something about this !
And BTW ... snow is expected UP HERE later tonite and through Wednesday !!
[Re: BB65Barracuda]
#271822
04/05/09 07:24 PM
04/05/09 07:24 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
Are you trying to do a 2nd gear burn out with the tires dry?
[Re: WILD BILL]
#271823
04/05/09 08:16 PM
04/05/09 08:16 PM
Posts: 926 MICHIGAN
BB65Barracuda
MICHIGAN
Yes I am, Not a good idea I take it? Its just the kid in me I guess I love my car, its a blast. The car launches wheels spinning every time I get into the gas from a stop. It reminds me of my 68 charger 4406 4spd car I had as a 18 year old kid. Those were the days. Im thinking it will hook up with the slicks on as soon as we shovel the drag strip.
[Re: BB65Barracuda]
#271826
04/05/09 08:36 PM
04/05/09 08:36 PM
WILD BILL
BROOK PARK, OH
I would venture to say the trans is fine.
The problem might be a loose nut behind the wheel.
[Re: 440challenger]
#271827
04/05/09 08:39 PM
04/05/09 08:39 PM
WILD BILL
BROOK PARK, OH
I always start my burnouts in 2nd gear wet or dry. I thought it was bad to start it first on a mopar 727
Only a bad idea if you have a VB that does not have a LBA.
[Re: WILD BILL]
#271830
04/05/09 08:48 PM
04/05/09 08:48 PM
Posts: 926 MICHIGAN
BB65Barracuda
MICHIGAN
Ok Bill I give up. Whats an LBA?
[Re: BB65Barracuda]
#271834
04/06/09 08:48 PM
04/06/09 08:48 PM
Posts: 3,967 S.I. N.Y.
1MYTGTX
S.I. N.Y.
I am running a full manual reverse VB as well with my stock shifter. No low band apply in first I was tired of missing second gear at times & going straight to third with the stock shifter. I worked with Tom Duncan of http://www.duncan-motor-sports.com/2.html to make up a reverse pattern for his Shift-R-Gate. I was his test mule Its a slap stick style from the 1-2 shift (no button press) then the 2-3 requires a button press....no more missed 2nd gear! from 3-2-1 it is a ratchet (no button press) with a lock before Neutral
1MYTGTX
[Re: MNobody]
#271838
04/15/09 08:12 PM
04/15/09 08:12 PM
Posts: 571 Western NC
68Bullit
Western NC
Ok i gotta ask, why no burnout's in first gear with a reverse manual VB?
My thoughts too actually. Also, how would you know if you have LBA in 1st? Is that when you shift back into first on the roll, and it spins as though it's in neutral?
[Re: 68Bullit]
#271840
04/15/09 11:38 PM
04/15/09 11:38 PM
Posts: 4,884 Michigan
MNobody
If it free wheels in first theres no LBA
