Re: A Body Headers
[Re: Cab_Burge]
#2717581
11/19/19 03:42 PM
11/19/19 03:42 PM
Posts: 4,220 West Plains, MO
DrCharles
West Plains, MO
As I've said before, the Hooker fenderwell headers were a big hit... they hit the tires. They hit the ground. They hit the steering. Etc. ![whistling whistling](/ubbthreads/images/graemlins/custom/whistling.gif) Not to mention roasting my (and any passenger's) feet due to the position right behind there. For a drag-only car that you don't mind cutting up, I could see it, but OP wanted street-strip. ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) Tri-Y's are good up to 450(?) hp. They'd be a good but somewhat limiting choice, depending on his plans for improvements later.
Re: A Body Headers
[Re: superwrench]
#2717747
11/20/19 12:57 AM
11/20/19 12:57 AM
Posts: 2,363 Cotati, CA
Dave Hall
Cotati, CA
Price a set of custom, stainless and pay more than 2K just for the material. Makes the TTI's a bargain. I don't know how smaller they can make them? FWIW the one's on my 73 Dart Sport 400 B engine are huge. Like 4 ft. long! It's these here. They take up a lot of space and supposedly won't work with power steering. I couldn't get the column gear linkage to work on mine. TTi says MAY need modification. So add $300 for a new cable shifter of your liking if it's auto.
Re: A Body Headers
[Re: Dave Hall]
#2717766
11/20/19 06:02 AM
11/20/19 06:02 AM
Posts: 4,788 Holland MI Ottawa
2boltmain
Holland MI Ottawa
The B body headers sound like a bargain. Nothing wrong with a cheap header if it works. (works well enough for its owner). Maybe a B body Hedman header but their thicker steel Elite series? Still affordable but more durable than entry level thin tube thin flange Hedmans?
Keep old mopars alive.
Re: A Body Headers
[Re: superwrench]
#2717908
11/20/19 07:33 PM
11/20/19 07:33 PM
Posts: 736 New York
R/T1968R/T
New York
What you will save in $$$$$ you will gain in headaches!! TTI or Proparts. I put Proparts in the Valiant and was amazed how easy they went in.
Re: A Body Headers
[Re: R/T1968R/T]
#2717921
11/20/19 08:30 PM
11/20/19 08:30 PM
Posts: 43,293 Bend,OR USA
Cab_Burge
The new Pro Part A body 2 1/8 inch headers sold by Bob Mazolini are made by TTI for him ![work work](/ubbthreads/images/graemlins/custom/work.gif)
