trans builders-late model 904 lockup guts into #2716331
11/16/19 10:59 AM
11/16/19 10:59 AM
illinois
rbkt65 Offline OP
rbkt65  Offline OP
illinois
64 push button 904 .bs session talking about putting late model 904,low gear set, lockup guts into a 64 push button trans. we know 64 trans has rear pump and bracket on vb that move manual valve is different. we also heard that imperial services(we think that is correct) will change over a later trans to work with your pb setup. anything we are not seeing/thinking about that would prevent this change over? thanks in advance.
Re: trans builders-late model 904 lockup guts into [Re: rbkt65] #2716339
11/16/19 11:25 AM
11/16/19 11:25 AM
moparx Offline
moparx  Offline
imperial services have many reports about not returning your valvebody and pushbutton assembly in a timely fashion when you sent it in for that modification.
however, it seems that a reputable transmission company recently bough out imperial services [A&A perhaps ?], so if someone could confirm if this is true, i would be contacting them instead.
beer
Re: trans builders-late model 904 lockup guts into [Re: moparx] #2716374
11/16/19 12:52 PM
11/16/19 12:52 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
beer
I talked to A&A at Carlisle and they seem to have taken that over. He sells the kits to convert the cable column and console shifts to the later trans too. The column and console shifters don't need anything but his cable kit but you have to send your pushbutton shifter in to him to be modified to work with the new cable control.
He had them in stock for sale.
Kevin
Re: trans builders-late model 904 lockup guts into [Re: Twostick] #2716443
11/16/19 03:42 PM
11/16/19 03:42 PM
illinois
rbkt65 Offline OP
rbkt65  Offline OP
illinois
thanks. will get on a&a web site shortly. thanks again
