I bought my ‘74 W200 in 2014.
One of the early things I bought, was a 1974 Dodge Factory Service Manual for Dodge Trucks. You can likely find a Hard (paper printed) copy from a Manuals Supply company (online) or (cheaper) get a downloadable version of a scanned manual.
The Service Manual explain a lot, along with specs, etc.Very helpful in making repairs. You don’t know what you don’t know without it.
My W200 is Manual Transmission with divorced transfer case.
A driveshaft repair Shop should be able to look up which Yokes and u-joints are correct for your truck (if it hasn’t been modified away from factory parts).. You should also be able to measure parts (caps, openings) you still have and look up the specs (dimensions) that would correspond to which u-joints you need.
