Re: Custom grill? 30's coupe? Not a BBQ either.
[Re: codfish]
#2707340
10/16/19 06:39 PM
10/16/19 06:39 PM
Posts: 1,335 Oregon
earlymopar
It would certainly be easier to make and fit a one-piece grill versus 2 pieces but I wouldn't cut out the center section of your grill shell due to the structure and rigidity you would lose. I had a similar issue with my 37 pickup but I had the side pieces and not the center section (at least not a good center section). So, I made my own while I was straightening and salvaging the grill shell.
- EM
[Re: burdar]
#2708189
10/18/19 08:13 PM
10/18/19 08:13 PM
Posts: 10,563 Freeport IL USA
poorboy
Freeport IL USA
I had a 35 Dodge, on mine the center piece really wasn't needed for support, if anything it was adding something for the bottom of the grill surround to attach to. The grill surround, if in good condition, is self supporting. The center piece probably added support for the vertical bars for each 1/2 grill. All the early Mopar grills I've seen were basically folded sheet metal attached at the top and bottom, with a couple cross braces between the top and bottom pieces, nothing very robust at all. I suspect by 37 Mopar decided they wanted to give those individual vertical folded sheet metal bars additional center support.
If your goal is to make a custom grill, I wouldn't let the center piece be a distraction, as long as your grill design can withstand the air movement at speed and won't fold up in the middle. Gene
[Re: codfish]
#2708271
10/19/19 09:12 AM
10/19/19 09:12 AM
Posts: 19,408 north of coder
moparx
instead of solid stock, i would use tubing. the reason being that size tubing would be lots easier to bend into the shape and style you decide on, and would be plenty strong for the purpose intended. it would also be considerably lighter.
[Re: codfish]
#2709457
10/23/19 11:08 AM
10/23/19 11:08 AM
moparx
Your center section is not a part of the body, is it? It's attached to the grill? Am I correct in saying that?
Gary if i remember correctly, the center section bolts to the grille insert with a few bolts and a couple more at the top and bottom of the shell. the 38 mounts the same way.
[Re: moparx]
#2709646
10/23/19 08:37 PM
10/23/19 08:37 PM
poorboy
Freeport IL USA
Gary if i remember correctly, the center section bolts to the grille insert with a few bolts and a couple more at the top and bottom of the shell. the 38 mounts the same way. Yes, another way of putting it is the piece between the 2 sides of the hood is not part of the grill shell on the 38, it is bolted to the grill housing. The center piece in the grill should bolt to the bottom and the top of the surrounding grill piece. Gene
[Re: poorboy]
#2709735
10/24/19 09:31 AM
10/24/19 09:31 AM
moparx
thanks for the clarification gene. my 38 has been gone since around the 1985ish time period. i had a complete 37 clip [hood, fenders, lights, grille, etc] that was in way better condition than the original 38 tin, and i believe a guy can swap the complete clip, which i was planning to do. but the car got sold before that happened. anyway, i know you can't just swap individual pieces from year to year, as they are year specific. sorry for the hijack. back to your regularly scheduled program.
