Page 22 of 34 1 2 20 21 22 23 24 33 34
Re: Starting to work on the Duster [Re: AndyF] #2701590
09/27/19 11:29 PM
09/27/19 11:29 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
Andy
My bass boat has the identical relay wired inti the trolling motor battery lines
Not sure who makes it, but not MSD on it
They should be available if you want to start making those plates.
Old Geezer Racing
Re: Starting to work on the Duster [Re: SCATPACK 1] #2701608
09/28/19 12:48 AM
09/28/19 12:48 AM
AndyF Offline OP
AndyF  Offline OP
I hadn't thought of making the sub panel as a product but I probably could. I have the equipment to press the nuts and standoffs into the plate so it is simple for a guy to just buy the other parts and assemble it. I think a panel like this would work for most race cars. The fuse module has 12 circuits and the relay bank has 4 relays in it so a person can run fans, fuel pump, electric pump, etc. I'll think about it.
Re: Starting to work on the Duster [Re: AndyF] #2701617
09/28/19 02:19 AM
09/28/19 02:19 AM
WA
P
pro451bee Offline
pro451bee  Offline
P
WA
These solid state relays are used extensively in modern cars and failure is common , the entire unit or fuse center has to be replaced if one relay circuit goes down. A relay over lay is possible in some instances however.
Re: Starting to work on the Duster [Re: AndyF] #2702646
10/01/19 02:42 PM
10/01/19 02:42 PM
Colorado front range
BcudaChris Offline
BcudaChris  Offline
Hey Andy,
Since you're pondering a product, a scaled back panel for assisting with FI conversions would be most welcome I'm sure (and probably at a higher margin). Powering a panel properly and running the circuits from there would be a good bit simpler and cleaner than working with the car's electrical system.
Re: Starting to work on the Duster [Re: BcudaChris] #2703097
10/02/19 03:52 PM
10/02/19 03:52 PM
AndyF Offline OP
AndyF  Offline OP
About the only clever thing I know to use for Mopar EFI conversions is a time delayed relay that allows the IGN1 and IGN2 circuits to be tied together to provide 12 volts when cranking and running. I've seen it done before but I haven't done it myself. Otherwise the EFI systems that I've seen installed just need power and ground and some sensors hooked up.
Re: Starting to work on the Duster [Re: AndyF] #2703142
10/02/19 05:26 PM
10/02/19 05:26 PM
BcudaChris Offline
BcudaChris  Offline
Ahhh, gotcha. I was thinking along the lines of having the fuel pump circuit on there, nab power for the FI unit there too and maybe some extra taps for nitrous, stereo, whatever. Strictly speaking, more of an elaborate bus than a sub-panel I guess.
I've done the electrical hookup work on a couple of Fi-Tech/in tank pump conversions and I pondered such a thing. Get an adequate power wire to it and a good ground, and you have a nice tidy power center in the back of the car and isolated from the factory electrical system. You'd have to go back to the front with power for the FI unit, and maybe run switched power signal back there as well. I'd love to have a convenient bus in the trunk.
Re: Starting to work on the Duster [Re: AndyF] #2711733
10/31/19 09:04 PM
10/31/19 09:04 PM
AndyF Offline OP
AndyF  Offline OP
Latest article in Car Craft: https://www.hotrod.com/articles/high-tech-mopar-setting-up-holleys-pro-dash/
The Duster is running and driving now but not quite complete. I'm waiting for the dash to come back from the paint shop and then the windshield and trim have to go back in. I also need to do some fab work on some front sheet metal parts to get things to fit the way I want. Otherwise she is finished up.
Re: Starting to work on the Duster [Re: AndyF] #2711751
10/31/19 10:00 PM
10/31/19 10:00 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
I have a black steering wheel for that thing that I can drop off next time I'm over. I have the black column as well but it's got a shifter sticking out of it.
Re: Starting to work on the Duster [Re: @#$%&*!] #2711760
10/31/19 11:03 PM
10/31/19 11:03 PM
AndyF Offline OP
AndyF  Offline OP
A black steering wheel would be cool. My interior is a mixture of blue and black right now. The car originally had a blue interior but some reproduction stuff is only available in black so I ended up with a jumble of colors. Let me know on the wheel.
Re: Starting to work on the Duster [Re: AndyF] #2712134
11/02/19 04:03 PM
11/02/19 04:03 PM
Indianapolis In. usa
Quickrunner Offline
Quickrunner  Offline
Love the way this car is coming along. Cant wait to see how finished dash comes out.
05 Ram 1500 Daytona package
71 Demon Gen3 hemi drag radial project
Missin' my 9 second 70 runner!
Re: Starting to work on the Duster [Re: Quickrunner] #2712579
11/04/19 12:37 AM
11/04/19 12:37 AM
AndyF Offline OP
AndyF  Offline OP
The dash is at the body shop getting a coat of B5 texture paint. Once I get that installed then the windshield can go back in and the car will be ready to go.
Right now I'm spending my time trying to get the front sheet metal hung correctly. It takes time to get everything lined up nice and square.
Re: Starting to work on the Duster [Re: AndyF] #2712583
11/04/19 03:18 AM
11/04/19 03:18 AM
Cab_Burge Online work
Cab_Burge  Online Work
That ;looks good just like it sits up bow
Are you going to paint the entire car B5 blue also?
Re: Starting to work on the Duster [Re: Cab_Burge] #2712643
11/04/19 11:55 AM
11/04/19 11:55 AM
AndyF Offline OP
AndyF  Offline OP
No, I'm going to leave the car in primer for now. I might paint it down the road or I might let the next guy paint it. The front clip was painted Spinnaker White.
Re: Starting to work on the Duster [Re: AndyF] #2713020
11/05/19 02:26 PM
11/05/19 02:26 PM
AndyF Offline OP
AndyF  Offline OP
Okay, now she is ready to fire up and pull out of the shop for the first time in 10+ years.
Re: Starting to work on the Duster [Re: AndyF] #2713031
11/05/19 03:06 PM
11/05/19 03:06 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Cool. Looks real nice Andy.
Re: Starting to work on the Duster [Re: mopar dave] #2713041
11/05/19 03:26 PM
11/05/19 03:26 PM
Northern Bavaria / Germany
MichaelF Offline
MichaelF  Offline
Cool, good luck! CanĀ“t wait for timeslips up
Michael
Re: Starting to work on the Duster [Re: MichaelF] #2713847
11/07/19 10:32 PM
11/07/19 10:32 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Looking real good Andy .
I really like the turntables in that alignment picture laugh2 Great idea.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Starting to work on the Duster [Re: fourgearsavoy] #2714890
11/11/19 06:22 PM
11/11/19 06:22 PM
ontario canada kingston
aspenrt360 Offline
aspenrt360  Offline
Very very nice!
2013 Chrysler 300 touring 1974 Dodge Charger SE. 360-727-8.75-3.23 sure grip 1972 Dodge Dart Swinger 1995 Dodge Ram 1500 4x4
Re: Starting to work on the Duster [Re: aspenrt360] #2714930
11/11/19 08:29 PM
11/11/19 08:29 PM
AndyF Offline OP
AndyF  Offline OP
Thanks. I put the finishing touches on the front sheet metal and I was able to finally figure out the exhaust tips. Everything takes so long to do on these projects it is hard to stay motivated. The exhaust tip install took several weeks by itself. I tried a few different tips then once I selected these I had to cut away the existing brackets and fabricate new ones. Seems like it would be a 30 minute job to install exhaust tips but not when everything is custom. Same with the front spoiler and the grill support. Lots of fab work required since the core support was modified and relocated. Everything else got shoved around by custom core support.
Re: Starting to work on the Duster [Re: AndyF] #2714935
11/11/19 08:35 PM
11/11/19 08:35 PM
Those tips look a lot like the ones I used on my 1966 Coronet up
