Re: Can anyone explain this 956 radiator top ?!?!
[Re: autoxcuda]
#270024
03/29/09 12:01 AM
03/29/09 12:01 AM
Posts: 990 Norwalk, Ohio
sycboi
Norwalk, Ohio
Upper hose outlet very short?
-Michael
SuperBeast
An enforcer for the Mopar Mafia!
[Re: sycboi]
#270025
03/29/09 12:18 AM
03/29/09 12:18 AM
Posts: 27,468 So Cal
autoxcuda
So Cal
-Michael
No, but here's a hint.
[Re: autoxcuda]
#270027
03/29/09 12:30 AM
03/29/09 12:30 AM
sycboi
Norwalk, Ohio
Outlet on wrong side? I really have no idea. I just wanted to play along, lol...
-Michael
SuperBeast
[Re: sycboi]
#270029
03/29/09 12:51 AM
03/29/09 12:51 AM
autoxcuda
So Cal
-Michael
Correct, outlet was on the wrong side AND the raised section of the tank was on the wrong side too for a big block B/E upper hose routing.
We figured it was a mistake stamped tank.
Yes, it had a tag over the 956. You can see the solder remaining. I think the tag number over it might have been for a T/A. Can't remember what he said exactly and it that tag was not with the tank.
Someone was trying to show me today how you could pinch your hands between an unmodified trunk lid hinge and a Superbird wing if the factory didn't put spacers in there. Never knew that... And this radiator top was in the trunk.
[Re: Snoopy]
#270035
03/29/09 01:54 AM
03/29/09 01:54 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Stampings on top of radiator won't be correct.
After vtaking a second look your right, the lettering would be on the wrong areas... pretty wild...
[Re: Snoopy]
#270036
03/29/09 01:55 AM
03/29/09 01:55 AM
autoxcuda
So Cal
I agree, the numbers will end up on the wrong side.
The tough part about it is that raised wide section that goes with the inlet tube.
Bummer is, it's a pretty nice condition top tank.
[Re: 6bblgt]
#270038
03/29/09 02:01 AM
03/29/09 02:01 AM
autoxcuda
So Cal
That top tank is small block only w/outlet on the driver's side, there is only one flat for the outlet.
But yet, it was stamped (incorectly) for a 956 big block tank.
Factory goof ?!?
[Re: 6bblgt]
#270040
03/29/09 02:26 AM
03/29/09 02:26 AM
autoxcuda
So Cal
Yes, stamping error & re-numbered. Was this out of a T/A?
340+6 440+6 whatever it takes rebuild it & make new friends via Ebay!!
No, not out of a T/A. I think junk yard or swap meet deal. The owner of it might be toying with using it for a 70 Hemi 'Bird clone. But really I think its more of a conversation piece.
To make it actually work/look correct in car you'd have to section the flat part and solder in to the passenger side with the inlet tube. I don't think that would make the most reliable functioning tank though.
You could probably sell it to some unsuspecting soul on ebay. I bet you wouldn't be long terms friends with them though.
[Re: Snoopy]
#270042
03/29/09 02:45 AM
03/29/09 02:45 AM
autoxcuda
So Cal
If the 5 digit number is a vendor code, different vendors made the radiators?
I did notice that number was different too. I can imagine there being two or more vendors for all of Chrysler's radiators.
