Can anyone explain this 956 radiator top ?!?! #270023
03/28/09 11:32 PM
03/28/09 11:32 PM
So Cal
autoxcuda Offline OP
So Cal
Quiz question....
What wrong with this picture of an 956 radiator top?
https://board.moparts.org/ubbthreads/upload2/5126333-956MistakeRadTop1.JPG
Re: Can anyone explain this 956 radiator top ?!?! [Re: autoxcuda] #270024
03/29/09 12:01 AM
03/29/09 12:01 AM
Norwalk, Ohio
sycboi Offline
sycboi  Offline
Norwalk, Ohio
Upper hose outlet very short?
-Michael
SuperBeast
An enforcer for the Mopar Mafia!
Re: Can anyone explain this 956 radiator top ?!?! [Re: sycboi] #270025
03/29/09 12:18 AM
03/29/09 12:18 AM
So Cal
So Cal
-Michael
No, but here's a hint.
Re: Can anyone explain this 956 radiator top ?!?! [Re: autoxcuda] #270026
03/29/09 12:27 AM
03/29/09 12:27 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Thats for the elusive 383 Hemi.
Re: Can anyone explain this 956 radiator top ?!?! [Re: autoxcuda] #270027
03/29/09 12:30 AM
03/29/09 12:30 AM
Norwalk, Ohio
sycboi Offline
sycboi  Offline
Norwalk, Ohio
Outlet on wrong side? I really have no idea. I just wanted to play along, lol...
-Michael
SuperBeast
Re: Can anyone explain this 956 radiator top ?!?! [Re: 62maxwgn] #270028
03/29/09 12:30 AM
03/29/09 12:30 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
What part number tag was soldered over the 956 number? You do not show that.
Re: Can anyone explain this 956 radiator top ?!?! [Re: sycboi] #270029
03/29/09 12:51 AM
03/29/09 12:51 AM
So Cal
So Cal
-Michael
Correct, outlet was on the wrong side AND the raised section of the tank was on the wrong side too for a big block B/E upper hose routing.
We figured it was a mistake stamped tank.
Yes, it had a tag over the 956. You can see the solder remaining. I think the tag number over it might have been for a T/A. Can't remember what he said exactly and it that tag was not with the tank.
Someone was trying to show me today how you could pinch your hands between an unmodified trunk lid hinge and a Superbird wing if the factory didn't put spacers in there. Never knew that... And this radiator top was in the trunk.
Re: Can anyone explain this 956 radiator top ?!?! [Re: Alaskan_TA] #270030
03/29/09 12:51 AM
03/29/09 12:51 AM
Walla Walla, WA
Hemi_Jack Offline
Hemi_Jack  Offline
Walla Walla, WA
The number or the outlet is on the wrong side of the tank, at least the one I have the number is on the same side as the outlet.
Re: Can anyone explain this 956 radiator top ?!?! [Re: Hemi_Jack] #270031
03/29/09 01:05 AM
03/29/09 01:05 AM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Comparison
Re: Can anyone explain this 956 radiator top ?!?! [Re: Snoopy] #270032
03/29/09 01:16 AM
03/29/09 01:16 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
And any competent radiator shop could move that hose fitting & plug the extra hole so it couldn't be seen quite easily...
Re: Can anyone explain this 956 radiator top ?!?! [Re: 1_WILD_RT] #270033
03/29/09 01:30 AM
03/29/09 01:30 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
So based on Snoopy's side by side shot, spin it 180 degrees & drill a new hole for the hose fitting & it is "correct".
More on re-numbered radiators at this link;
http://www.challengertaregistry.com/radiators.html
Re: Can anyone explain this 956 radiator top ?!?! [Re: Alaskan_TA] #270034
03/29/09 01:34 AM
03/29/09 01:34 AM
Snoopy Offline
Snoopy  Offline
Stampings on top of radiator won't be correct.
Re: Can anyone explain this 956 radiator top ?!?! [Re: Snoopy] #270035
03/29/09 01:54 AM
03/29/09 01:54 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
After vtaking a second look your right, the lettering would be on the wrong areas... pretty wild...
Re: Can anyone explain this 956 radiator top ?!?! [Re: Snoopy] #270036
03/29/09 01:55 AM
03/29/09 01:55 AM
So Cal
So Cal
I agree, the numbers will end up on the wrong side.
The tough part about it is that raised wide section that goes with the inlet tube.
Bummer is, it's a pretty nice condition top tank.
Re: Can anyone explain this 956 radiator top ?!?! [Re: autoxcuda] #270037
03/29/09 01:58 AM
03/29/09 01:58 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
That top tank is small block only w/outlet on the driver's side, there is only one flat for the outlet.
Re: Can anyone explain this 956 radiator top ?!?! [Re: 6bblgt] #270038
03/29/09 02:01 AM
03/29/09 02:01 AM
So Cal
So Cal
But yet, it was stamped (incorectly) for a 956 big block tank.
Factory goof ?!?
Re: Can anyone explain this 956 radiator top ?!?! [Re: autoxcuda] #270039
03/29/09 02:08 AM
03/29/09 02:08 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Yes, stamping error & re-numbered. Was this out of a T/A?
340+6 440+6 whatever it takes rebuild it & make new friends via Ebay!!
Re: Can anyone explain this 956 radiator top ?!?! [Re: 6bblgt] #270040
03/29/09 02:26 AM
03/29/09 02:26 AM
So Cal
So Cal
No, not out of a T/A. I think junk yard or swap meet deal. The owner of it might be toying with using it for a 70 Hemi 'Bird clone. But really I think its more of a conversation piece.
To make it actually work/look correct in car you'd have to section the flat part and solder in to the passenger side with the inlet tube. I don't think that would make the most reliable functioning tank though.
You could probably sell it to some unsuspecting soul on ebay. I bet you wouldn't be long terms friends with them though.
Re: Can anyone explain this 956 radiator top ?!?! [Re: autoxcuda] #270041
03/29/09 02:34 AM
03/29/09 02:34 AM
Snoopy Offline
Snoopy  Offline
If the 5 digit number is a vendor code, different vendors made the radiators?
Re: Can anyone explain this 956 radiator top ?!?! [Re: Snoopy] #270042
03/29/09 02:45 AM
03/29/09 02:45 AM
So Cal
So Cal
I did notice that number was different too. I can imagine there being two or more vendors for all of Chrysler's radiators.
